It is currently Tue Apr 23, 2024 6:30 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 52, 53, 54, 55, 56
PostPosted: Sun Mar 25, 2018 7:08 pm
mocking up the down pipe ready fro Tig welding
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sat Mar 31, 2018 3:41 pm
down pipe all tig welded up, and now sorting the custom tension adjuster bar made for the alternator and started to mock up the external waste gate pipe
BRD Page
PostPosted: Thu Apr 05, 2018 7:08 pm
new bracket fitted, now to sort out the thermostat housing pipe and header tank pipe
BRD Page
PostPosted: Sat Apr 07, 2018 7:40 pm
and that's the wastgate pipe all mocked up and ready to get welded
and the extended thermostat housing
BRD Page
PostPosted: Tue May 01, 2018 9:05 pm
down pipe done
new filter to fit
BRD Page
PostPosted: Sat May 05, 2018 6:59 pm
not far off now, just a few turbo coolant pipes to sort out and the hot feed to FMIC to make up.
BRD Page
PostPosted: Sat May 19, 2018 8:12 pm
out side on its own power
BRD Page
PostPosted: Sat Jun 09, 2018 9:00 pm
busy day fitting the GTR FMIC and the RS turbo radiator. the rad has now be moved forward to sit 1" of the back of the FMIC to give it better air flow through it for better cooling, next is to finish of the ducting and then plumb the rad and the FMIC up. but this should all help keep charge temps and water temps down. Oh and a bit of fiberglass work on the bumper to tidy it up
BRD Page
PostPosted: Sat Jul 21, 2018 6:26 pm
new rad bleeds welded in and piping made back to the header tank
new oil catch tank fitted and plumbed in
and new gear box cooler fitted ready to plumb in
BRD Page
PostPosted: Sat Aug 04, 2018 6:34 pm
bit more done  gear box cooler now plumbed in and rad fitted,  just a few more radiator pipes to make up and then thats the rad all plumbed on
BRD Page
PostPosted: Sat Aug 18, 2018 3:53 pm
mocking up the new adaptor plate and pipe work so it clears the alternator adjustment bar for the BRD track car. there will be a built in O ring seal on the back when finished
BRD Page
PostPosted: Sun Sep 23, 2018 1:30 pm
thats the new fmic fitted with 12" fan and new thermostat hosing and pipe fitted all working as planed
BRD Page
