It is currently Fri Oct 10, 2025 3:35 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 02, 2006 8:19 pm
datajon wrote:
The CS throttle body rubber will fit over 2 ½” pipe work, but they don’t last.
I ran one for a few miles, 2k Touching boost limit of 20 psi or so, it just split after a few hard runs.. In my view a waste of time to use them.
Tone I use 63.0mm stainless steel pipe work as the throttle body joiner, to a 55mm throttle body for now, with an internal belmouth.
I can machine it from one piece if need be.
Can’t see the 205 charge cooler outlet being 70mm, maybe the external diameter is , less wall thickness, equals ? .....it’s the ID thats important for the flow..
The 205 run’s a 60mm TB, 5mm larger than a 185.
Unless running 65, or 70 mm TB very little point in increasing the pipe size, better off making sure all the welds inside the pipe work have been cutback, if left will cause major flow restrictions, thus reducing the overall gains of the upgrade.
What every you need Tone, I can make up in house, if you want it sorted, why not pope down, do it while you wait, that way you know it will fit and work..
I'll reply to you datajon when I have mulled this over in my nugget and had a bit to eat. Maybe I need to go measure the outlet for a third time :?
Cheers for the help much appreciated.
Tone
Now offering:
PostPosted: Thu Mar 02, 2006 8:20 pm
Hi Tone, np :-)
Jon, did you use an old T/Body rubber or a brand new one that split?
afaik there are loads of guys in the usa doing this and a ST 165 owner here has been using the rubber also?
What bolts do you use with your adapter, i have had some issues getting small enough bolts to allow me to use the jubilee clip etc
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Fri Mar 10, 2006 10:11 am
Hi.
I used a CS TB rubber, yes it was old, but look in A 1 condiction..
only used it, to get the thing running, then forgot about it, coming back one day, giving it a few miles of wot, suddenly the engine noise change, loss of power, the complete rubber had split...some gaffer tape, silicon, was all i had on board for a temp fix.
after that , i made and welded what i use now..
