It is currently Wed Oct 08, 2025 5:48 am
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Tue Feb 21, 2012 6:09 am
Ive already spoke to him about the bells maybe we should chat spec and speak to him.as for the link isnt that the hub carrier/bearing the bits i had made are what slot in the bearing/hub carrier with the studs on.
PostPosted: Mon Mar 19, 2012 8:31 pm
just an update the engineers sent out the test peice i had commissioned today so that should be here in a couple of days ive also got another local engineers tapping out all the brake servo,power steering turbo feeds and returns ready for all the -AN fittings been busy beavering away making ally flanges for all sorts of bits dropped a bomb on fittings and tube, oil coolers etc so once i start fitting i upload some pics of the progress looking to get her on the rollers in 8 weeks but now we have some better weather things will have to move up a few gears report back soon, Bazza.
PostPosted: Sat Mar 24, 2012 9:21 pm
Ok so the faffs been on hold as ive had some bad news from being in hospital of late but i pushed myself this week end to at least try and get some enthusiasm back in to the ST205 so the test piece i had commissioned turned up for a test fit which i havnt done but i finished making all the flanges out of aircraft grade 10mm ally for the -AN fittings turned an old toyosports catch can into the new power steering bottle really need to get on with putting some of the stuff ive done recently on the actual car instead of just looking at it....:lol:
PostPosted: Sat Mar 24, 2012 9:49 pm
thats some great work 8)
is the turbo adapter also out of alu :lol:
PostPosted: Sun Mar 25, 2012 9:24 am
The t3/4 adapter in the pic is the test piece which is in ally but the proper part is in A4 grade s/steel.
PostPosted: Sun Mar 25, 2012 11:21 am
Would 321 stainless be better for the turbo adaptor plate?
PostPosted: Sun Mar 25, 2012 11:37 am
Not sure chris thought the above would be ok?
PostPosted: Sun Mar 25, 2012 2:10 pm
A little info from wikki on stainless steel grades:-
Type 316—the second most common grade (after 304); for food and surgical stainless steel uses; alloy addition of molybdenum prevents specific forms of corrosion. It is also known as marine grade stainless steel due to its increased resistance to chloride corrosion compared to type 304. 316 is often used for building nuclear reprocessing plants. 316L is an extra low carbon grade of 316, generally used in stainless steel watches and marine applications, as well exclusively in the fabrication of reactor pressure vessels for boiling water reactors, due to its high resistance to corrosion. Also referred to as "A4" in accordance with ISO 3506.[6] 316Ti includes titanium for heat resistance, therefore it is used in flexible chimney liners.
Type 321—similar to 304 but lower risk of weld decay due to addition of titanium. See also 347 with addition of niobium for desensitization during welding.
Maybe some one more educated in SS grades can comment?
Most exhaust manifolds are made from 321 but I assume that is due to being welded.
PostPosted: Sun Mar 25, 2012 6:26 pm
i aske a good friend who gives me the info that 1.4571 (V4A) ist the material of choice in front of availability, price and brittleness
if it is machined out of a block like you did
PostPosted: Sun Mar 25, 2012 6:50 pm
there was me thinking there was not much choice lol i did enquire about it in ti but the billet was much much pennies.
PostPosted: Sat Jun 09, 2012 10:59 pm
well this is what i got up to over the weekend its a bit pic heavy and once i got it all on i changed my mind and had to remove it all to get the oe pedal box and abs system out for a future upgrade to the braking system.
this ones just for good measure lol
PostPosted: Fri Jun 15, 2012 11:17 am
I think I have just had a sex wee in my undies
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Fri Jun 15, 2012 10:59 pm
Can you tell us what is the thread for the steering rack ?
thanks
PostPosted: Sun Jun 17, 2012 9:11 am
Its where i have swapped out standard type push on hose/jubilee clips for -AN fittings as it worked better for my power steering bottle and cooler set up.
PostPosted: Thu Jul 12, 2012 9:07 pm
Well most of the test fit has gone ok mm perfect in some cases some plans have changed along the way here are some more pics of progress it is slow bearing in mind the car only has 6 inches space either side to work in so im now a contortionist lol well ive now got a bad back but hey....
