It is currently Wed Oct 08, 2025 11:49 pm
PostPosted: Sun May 28, 2006 7:25 am
G'day fellas,
Im going down the front mount road with the GT4 and i was wondering if your code 54 write up applies for the ST185CS as well? Im planning on running a cooler from an evo 7. Will post up pics and progress as usual. I wanted to keep the WTA, but after some of the mods ive done, i will be able to gain more from a front mount.
Cheers
Shane
PostPosted: Sun May 28, 2006 10:07 am
No. The setup on the 205 is different to the 185. It should be much easier to fool the ECU on the 185.
Initial things I would look at:
1. Bridge the IC level sensor
2. Possibly just remove the pump, if this flags up an error at the ECU then I would think that a resistor is all that is required in place of the pump.
Will be interested to hear how you get on :)
PostPosted: Sun May 28, 2006 10:59 am
when i fitted a fmic to my 165, all i had to do was remove the chargecooler pump and bridge the chargecooler level sensor with a piece of wire.
Sprint ST165 aka "The 500BHP Sledgehammer" #6 in the Toyota Sprint Series. GT3071 1.9bar
PostPosted: Tue May 30, 2006 3:15 pm
Thanks for the heads up fellas. I will look into for sure.
Im looking at running either a 450 x 300 x 76 - 2.5 Inch inlet/outlet core or a 600 x 300 x 76 - 2.5 Inch inlet/outlet.
with 2.5" pipe work all around. What would you guys say is the best option, looking for least lag as possible.
I was even thinking 2" from turbo to the intercooler, then 2.5" from intercooler to TB?
Thanks
Shane
