speedometer converters http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=2861 |
Author: | Galwaygt4 [ Sun Mar 22, 2009 10:33 pm ] |
Post subject: | speedometer converters |
hi guys thinking about buying a speedo converter for my st205 just wondering have many of you done this and are there many problems?? also could you recomend one and where to source it thanks in advance guys |
Author: | Loosey [ Mon Mar 23, 2009 9:08 am ] |
I think HKS do one but don't quote me on that? My can was converted by the importer for me so I don't know what he used, but it has always been pretty good and pretty accurate (certainly no worse than the other 'uk' cars I have owned that read 70 when you are really only doing 65!) Perhaps one of the 'geeks' on here can help! Guys?! |
Author: | two_OH_five [ Mon Mar 23, 2009 10:07 am ] |
I don't know of any significant problems There's a doc on t'interweb somewhere that shows the 3 connections required on the back of the speedo cluster Are you looking to convert the speedo reading or remove the speed limiter or both? |
Author: | peterp1per [ Mon Mar 23, 2009 1:35 pm ] |
loads on ebay, and should only take about 30 mins to fit ![]() |
Author: | Galwaygt4 [ Mon Mar 23, 2009 10:55 pm ] |
two_OH_five wrote: I don't know of any significant problems
There's a doc on t'interweb somewhere that shows the 3 connections required on the back of the speedo cluster Are you looking to convert the speedo reading or remove the speed limiter or both? looking to do both do many units do this? il have a look on e bay and see what i can find. any ideas where i could find that doc?? thanks for all the help guys |
Author: | Muddy Water [ Tue Mar 24, 2009 11:32 pm ] |
I'm currently looking at the back of a spare cluster fitted with a convertor. In the middle of the cluster are four cross-head screws - each has a marking by the side of it. Top Left = SI Bottom Left = R Top Right = Y Bottom Right = E The way this convertor is wired is as follows: Blue wire from convertor to top left cross-head screw (SI); Red wire from convertor to bottom left cross-head screw (R); Green wire from convertor to bottom right cross-head screw (E). The convertor has a Grey wire that appears not to be used. The convertor has a Yellow wire that, I assume, connects to the Speed Sensor wire from the ECU. |
Author: | Galwaygt4 [ Wed Mar 25, 2009 7:14 pm ] |
thats great mate thanks. gonna order one next week and see how i get on ![]() |
Author: | peterp1per [ Wed Mar 25, 2009 7:38 pm ] |
ive got a pic if you want it aswell ![]() |
Author: | Galwaygt4 [ Wed Mar 25, 2009 8:00 pm ] |
peterp1per wrote: ive got a pic if you want it aswell
![]() That'd be great thanks. one im looking at has a fitting guide so between it all i should sort it. just saw a class set of white dials on flea bay so might fit them at the same time. better check the piggy bank first ![]() |
