"La GrOsse" cooling mod http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=4350 |
Page 2 of 3 |
Author: | Muddy Water [ Fri Feb 18, 2011 5:58 pm ] |
Truly amazing work On a side note I have been looking at the following concept: http://simtecmotorsports.com/Z32airdam.htm |
Author: | bozo-merlin [ Fri Feb 18, 2011 6:20 pm ] |
Muddy Water wrote: On a side note I have been looking at the following concept: Really like the way it's done, and the side duct for the oil cooler is a great inspiration.
http://simtecmotorsports.com/Z32airdam.htm A lot of job to be done ... thanks for those pics Muddy Water |
Author: | Sunny [ Fri Feb 18, 2011 8:29 pm ] |
Hi, wow, great job (both) greetz |
Author: | Meurz [ Fri Feb 18, 2011 11:51 pm ] |
Great DIY work mate! I've been toying with the idea of placing a smaller rad inside the nose frame as well and this gives me a lot of inspiration! Do you have temp data to see what difference the ducting makes? |
Author: | bozo-merlin [ Sat Feb 19, 2011 12:26 am ] |
I have some with the old setup But as i focus on water temp (my neverended issue) i don't log any IC temp before / after is those same conditions Golpher + EVO IC + 71° thermostat + free air flow : 71/72 on the road (normal driving style) 80/85 after 7/12 min of abuse on the road which is not a true abuse time 80/85 after 4/7 min of good lap time on a semi twisty track 95 after 13/15 min 105 after 18 min usually decided to slow down, short shift, ... to cool the engine down Oil temp never exceed 110° 4 track days pratice, ambiant temp varying from 11° to 19° Golpher + EVO IC + 71° thermostat + AirDuct v1 : 71/72 on the road (normal driving style) 75/80 after 10/15 min of abuse on the road 80/85 after 8/10 min of good lap time on a semi twisty track 95 after 21/24 min 105 after 31 min (only once as the practice usually last 20/25 min) Oil temp never exceed 120° 3 track days pratice, ambiant temp from 9° to 22° Didn't have experienced the new setup on the track nor the road yet Magny cours F1 track plan in march but log won't show anything as it's a F1 track and my car never suffer from overheated on such big and straight track |
Author: | bozo-merlin [ Sun May 29, 2011 9:57 pm ] |
Another small update After taking care on the front of the rad it's time to work on the back IY store, 1.5mm alloy sheet (as always now), pop rivet, time, time, time ... and time. Gearbox side : Engine side : Installed 2 step bumper floor to get 4mm lower As you can see i will try the "venturi effect" New engine oil cooler setup is under progress (19 rows, wide), i know how to put air on it but not how to best extract yet. May need some small loover on the slope (20° angled) ahead of the massive ones, have to try before add anything. Of course everything is removable with screws round head or CHc in 3 parts, even the bumper floor is attached with nut insert (cage nut?) |
Author: | Sunny [ Mon May 30, 2011 7:33 am ] |
Hi, wow, great work, but how did you do the air escapes? greetz |
Author: | bozo-merlin [ Mon May 30, 2011 8:47 am ] |
Sunny wrote: but how did you do the air escapes? That's the trick : DIY store example
Author: | Sirius [ Mon May 30, 2011 9:53 am ] |
Looks really good. I want to do something similar on my car. |
Author: | Jingo11 [ Tue May 31, 2011 2:24 am ] |
Does look very good i must say |
Author: | two_OH_five [ Tue May 31, 2011 12:04 pm ] |
Nice to see some professional grade work |
Author: | Muddy Water [ Tue May 31, 2011 5:07 pm ] |
O mon dieu C'est de travail magnifique |
Author: | mixer72 [ Thu Jun 02, 2011 10:59 pm ] |
looking rely good mate im doing the same sort of thing to mine |
Author: | Gary ST165 [ Thu Jun 02, 2011 11:53 pm ] |
its a real pleasure to come back to this thread. nice. |
Author: | bozo-merlin [ Mon Jul 04, 2011 12:45 pm ] |
Hotter ambiant temp cooling failed Even if it's good on track in march, after 7 min of road abuse i can clearly see 95° so something is not working correctly. Change my 13 oil rad to a 19 rows 2° less than before Oil is not the reason my engine heat like that Remove 3° timing (even if there is no det) 0° less than before but EGT grows a bit I then remembered my ASI vs Golpher experience, ASI is thicker and not as good as Golpher one, and this RS500 rad is really big with bar rows, could this be the issue ? I think only a few rows f this rad is enough for coolant to pass the rad, about 1/3, which is half confirmed by the heat on the rad : top is really hot, middle lukewarm and bottom really cold (normal on a vertical core but it's not my situation), i expected a hot right side to a cold left side. May I try a tri pass mod, if 1/3 is enough to pass water what are the risk ? |
Page 2 of 3 | All times are UTC + 1 hour |
