It is currently Thu Oct 09, 2025 8:08 pm
 Post subject: ST205 Tyres
PostPosted: Wed Jun 08, 2011 7:41 pm
I currently have the "hard to get hold of" 215/50/R16 KUHMO tyres on my ST205, could I use Bridgestone Potenza 225-50-16 92V Tyres(P389) instead, or any other 225/50/16?
PostPosted: Wed Jun 08, 2011 7:51 pm
225/40 R16 and the rolling circumference is nearly identical to OEM
PostPosted: Wed Jun 08, 2011 8:35 pm
Thanks for your reply.
Is that the only option or is there another size I could use?
Cheers
PostPosted: Wed Jun 08, 2011 9:18 pm
Have aplay with this :wink:
http://www.tyresave.co.uk/tyresize.html
Vice Chairman
PostPosted: Wed Jun 08, 2011 9:35 pm
the issue is the speedometer accuracy, it shows you to less or to much addicted about you have more or less rolling circumference
225/50 R16 also works as a friend of mine drives that size with a toyota approval
PostPosted: Wed Jun 08, 2011 11:00 pm
And be sure to use the same tyre size (circumference) all round in order to keep the diffs happy. :)
PostPosted: Thu Jun 09, 2011 12:47 am
I have used a 225/50/16 on my car for the last 8 years now. As long as you keep all the tyres the same it's fine.
PostPosted: Thu Jun 09, 2011 8:38 am
Thank you all for your input, I have decided to go with the 225/50/R16, all the way round of course.
Thanks again. Paul
PostPosted: Thu Jun 09, 2011 11:47 am
I normally use 205/50/16 as there's a bit less tramlining. Makes the speedo read about 5% high.
PostPosted: Mon Aug 01, 2011 10:07 pm
If it helps i'm running 225/50/R16 Kumho Ecsta KU31's on 7J rims.
One of the cheapest tyres on the market in this size but i swear by them.
Used to run Goodyear Eagle F1's but switched to these as they are half the price and 98% of the grip.
Users browsing this forum: No registered users and 3 guests
