http://www.gt4dc.co.uk/forum/
Gearbox st185 vs st205
http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=5219
Author:  Midnite [ Sat Oct 29, 2011 1:31 pm ]
Post subject:  Gearbox st185 vs st205
What is the difference if any between the st185 and st205 gearbox and transfer box.
Mine is a little crunchy on second and has a little whine and leak, i also spotted a dodgy looking half screwed in bolt when i was looking at it some time ago.
i might have an st205 gearbox/transfer box combo thats going cheap as it needs a rebuild.
are ratios same etc
cheers
Author:  Muddy Water [ Sat Oct 29, 2011 10:53 pm ]
Not sure of the difference in internals/ratios etc (if any) but...
they are definitely interchanglable.
Obviously the 205 box has been built to cope with greater bhp/torque of the 205 (over the 185).
I'm using a recon 205 gearbox for my 185 track car build
(albeit with a C-ONE gear set lurking inside).
Author:  Nibbles [ Sun Oct 30, 2011 10:30 am ]
I think there's a difference in the speed sensor but not 100% sure what. Otherwise interchangeable.
205 has better syncromesh.
Ratios are slightly different. Somewhere there's a post listing the variants and their ratios.
The 185 has the mode selection lever, 205 doesn't.
Author:  XLarge [ Sat Nov 05, 2011 2:24 am ]
The ST185 got a mechanic speedo drive, the ST205 got a electric one but they are interchangeable as they are only pluged into the gear box housing.
Author:  Nibbles [ Sat Nov 05, 2011 1:57 pm ]
My 185 has an electric speedo drive, as have all the others I've worked on. I have heard of some having mechanical drives though.
Author:  XLarge [ Sat Nov 05, 2011 9:46 pm ]
Strange. My CS and all (german) Celica T18 I know got a mechanic speedo drive.
Author:  bozo-merlin [ Sun Nov 06, 2011 9:07 am ]
every ST182/5 LHD have a mecanical speedo drive, dash and GB are on the same side ;)
every ST 182/5 RHD have an electric speedo drive for the same reason : a mechanical cable won't turn that easy on the other side
