http://www.gt4dc.co.uk/forum/
What Clutch should i buy? £310 to spend?
http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=5245
Page 1 of 2
Author:  pauln [ Wed Nov 16, 2011 6:58 pm ]
Post subject:  What Clutch should i buy? £310 to spend?
hi all
i have a 1991 gt4 and the clutch has been slipping for quite a few months and now i can finally buy a new one but im not sure which one to buy
firstly the car is running at around 250bhp
it has
front mounted intercooler
fuel management system
dump valve
boost set to 1.1 bar
so i want a decent clutch as im going to be doing more upgrades to the car over the next 18 months
my budget is £310
ive seen some good ones on ebay but thought i would check out this forum first to see what you guys say
many thanks
paul
Author:  johnyboy1976 [ Wed Nov 16, 2011 7:10 pm ]
Not sure how much a genuine item is but they are good if you dont constantly launch the car
Author:  darrylp [ Wed Nov 16, 2011 7:19 pm ]
had a clutch masters fx300, it only did 40K on the road. its release bearing failed on me.
whatever clutch you get, put a genuine toyota release bearing to it.
Author:  Kris [ Wed Nov 16, 2011 9:28 pm ]
If you're not dragging the car then fit a 205 clutch
Author:  johnyboy1976 [ Wed Nov 16, 2011 9:39 pm ]
sorry thats what i meant to say - a standard 205 clutch
Author:  pauln [ Wed Nov 16, 2011 11:38 pm ]
ok thanks for the replies
so are you saying that a standard 205 clutch would be better to buy than a exedy racing clutch?
also do you know the best places in the uk to order gt4 clutches from?
thanks
paul
Author:  TrackToyFour [ Thu Nov 17, 2011 12:19 am ]
I would also recommend an OEM ST205 clutch. Worked well in my 330bhp Four. Clutch and release bearings can be sourced here: http://www.tcbparts.co.uk/
Author:  Gary ST165 [ Thu Nov 17, 2011 1:00 am ]
Toyota "aisin" brand is OEM and organic material / full face clutch plate . good for up to 320 ft lbs & 100,000 miles if driven with mechanical sympathy
"exedy" race is likely to be a cerametallic puck type clutch, holds more torque on launching but will wear out within 20 - 40,000 miles
exedy also do cheaper organic clutches similar to OEM
nb: mr2 turbo clutches also fit: http://www.ebay.co.uk/sch/i.html?_trkpa ... p=15&_sc=1
Author:  pauln [ Thu Nov 17, 2011 10:26 am ]
this is the page that show some clutches which im considering buying
http://www.ebay.co.uk/sch/i.html?_trkpa ... 513&_pgn=2
is there much difference between the stage 1 and stage 2 clutch?
or would it NOT really make much difference?
thanks
paul
Author:  Gary ST165 [ Thu Nov 17, 2011 5:05 pm ]
thanks
paul
Stage 1
http://www.ebay.co.uk/itm/F1-RACING-STA ... 0650739250
Vehicle Application
Application: All Toyota 2L Turbo (3S-GTE)
Engine power must not exceed 240 bhp & 240 ft/lbs
Stage 2
http://www.ebay.co.uk/itm/F1-RACING-STA ... 0650739238
Vehicle Application
Engine power must not exceed 290 bhp & 290 ft/lbs
Author:  pauln [ Thu Nov 17, 2011 6:31 pm ]
ok thanks gary
i did see those f1 clutches but they look a bit tacky
this is the one ive been looking at
http://www.ebay.co.uk/itm/EXEDY-RACING- ... 5642cc6e4e
its good for 300 ft/lbs according to the guy i just spoke to
but not sure if this will be enough when i start tuning it up more though
paul
Author:  Gary ST165 [ Thu Nov 17, 2011 7:48 pm ]
That exedy unit is well over priced in my opinion for a stockish replacement organic unit, and the same identical unit is available here for £25 less: http://www.ebay.co.uk/itm/Exedy-Organic ... 0853423185
however, i'd still rather buy genuine Toyota / Aisin for less money or use the F1 racing.
..and to reiterate those organic type clutches will not tolerate drag launches, the torque / loading will cause them to slip and smell bad. .... but they do last along time under normal driving in town , stop. go. traffic etc
Author:  Meurz [ Thu Nov 17, 2011 11:40 pm ]
Fyi - Dunno if your dealers also sell Toyota Optifit parts as they do over here, but I'd stay away from those. It's a cheapo special series of parts that isn't worth the Toyota badge imo, go for Toyota Genuine Parts as they are also genuine Toyota quality.
Author:  pauln [ Fri Nov 18, 2011 12:02 am ]
hi gary
the problem is those f1 clutches on ebay, even the stage 2 one can only take 290bhp and i have intentions of taking mine over that kind of power
so those f1 clutches dont seem like a good idea
also i cant see a standard toyota clutch taking 300 bhp either
paul
Author:  pauln [ Fri Nov 18, 2011 12:13 am ]
how about this bad boy
http://www.ebay.co.uk/itm/F1-RACING-STA ... 4aa845fe07
its good for 370 ft/lbs = 390 bhp
thats more like it....
are these f1 clutches actually good then gary?
if anyone else have used these f1 clutches i would be interested to hear what you have to say about them
thanks
paul
