It is currently Sun Apr 28, 2024 3:07 pm
 Post subject: Sender Problems
PostPosted: Mon Jul 02, 2012 8:59 am
Is it just me or is the job of changing the oil pressure sender on a 205 JDM a real pain in the butt? I want to fit an extension hose so I can drive a pressure gauge whilst retaining the original sender to the idiot light. At first glance the jobs a good un- undo the charge cooler, tilt it to afford more room and away you go. Unfortunately though it hasn't quite panned out like that due to the lack of access. A large bracket obscures the frontal route meaning that all attempts with spanners, moleys etc are thwarted, so I initially reckoned that a tall socket would do it. However that plan was stymied by the suspension turret and the aforementioned bracket. I even considered removing the bracket but that's also a non-starter; one bolts ultra tight and the other two are really inaccessible.
From reading through the forums i see that many people have accomplished this mod so, at the risk of looking a complete front bottom could someone give me an idea of what I'm missing? thanks.
PostPosted: Mon Jul 02, 2012 10:46 am
Can you explain how the suspension turret is in the way?
The suspension is nowhere near the oil pressure sensor.
Users browsing this forum: No registered users and 167 guests
