http://www.gt4dc.co.uk/forum/
Two Peice Front Discs
http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=5920
Author:  jeffrosie6 [ Sun Sep 02, 2012 9:08 pm ]
Post subject:  Two Peice Front Discs
As nobody makes 2-poece discs fot the 205, was wondering if theses would work if redrilled?
http://www.ebay.co.u...=item2a1572974f
Or is there something else out there that would work?
Author:  jeffrosie6 [ Wed Sep 05, 2012 12:43 pm ]
nothing?
Author:  two_OH_five [ Wed Sep 05, 2012 12:55 pm ]
The link doesn't work Jeff and eBay doesn't recognize the item number
Author:  Pete Crease [ Wed Sep 05, 2012 1:03 pm ]
Would a two piece scooby disc with some sort of spacing not work? You could space the disc, calliper or both. Mind you I thought most big brake kits had some type if two piece rotor. Or find a big brake kit for something small that upgrades it to stock 205 size then use those discs once again with spacers or whatever.
Author:  jeffrosie6 [ Wed Sep 05, 2012 2:04 pm ]
Sorry about that guys - maybee that ebay link expired.
Hope this works :)
http://www.ebay.co.uk/itm/TOYOTA-SUPRA- ... 2a1572974f
The reason I'm looking at Supra discs is mainly because they are very similar to ST205 discs bar the pcd which can be fixed. Just seen that they are also 8mm larger.
But is lady luck on our side and the disc offset the same?
Author:  Sirius [ Wed Sep 05, 2012 3:55 pm ]
I might be wrong but those don't look like floating discs to me?
The mounting points between the bell and rotor appear to just be bolts - I thought in a floating design there was space to allow for expansion and contraction?
Author:  Insanity-74 [ Wed Sep 05, 2012 4:00 pm ]
If you look on places like Demon Tweeks, you can buy floating discs to pretty much any size, PCD, bell depth etc that you need, its just a matter of measuring an OEM disc. They dont appear to be that expensive either. No need to bodge it with discs from other cars.
Skoda Faboa vRS uses the same PCD and wheel offset as the ST205 so one of them might fit!
Author:  turbo_imp [ Wed Sep 05, 2012 4:59 pm ]
Not looking too hopeful?
Author:  jeffrosie6 [ Wed Sep 05, 2012 5:47 pm ]
Cheers guys
Insanity, found all the disc options with demon tweeks, but no bell options!
Please put up a link as I cant find it :)
Author:  Insanity-74 [ Wed Sep 05, 2012 6:25 pm ]
I dont know whats going on with the tweeks site, they were there last time I looked...which was a while ago. The new site is a bit rubbish, Try going directly to the manufacturers web sites.
I think its just a matter of looking at web sites like AP Racing or Tarox, you could try searching for some british brake manufacturers and seeing what they can do for you.
http://www.apracing.com/drawings/Indivi ... 0Discs.pdf
Author:  banzaibaz [ Sun Sep 30, 2012 5:25 pm ]
Jeff HI-SPEC will make what ever type combo set up you want .
"HiSpec Sales" <sales@hispecmotorsport.co.uk>
