It is currently Sat Apr 27, 2024 8:51 am
 Post subject: Clutchmasters FX400
PostPosted: Thu Aug 01, 2013 1:45 pm
I have one of the above and need a new friction plate. Where can I order one without ordering the whole kit?
I found this but not sure of quality and I would like to go for a more conventional plate (like a fx200-fx300-fx350..)
http://www.gtschris.com/store/comersus_viewItem.asp?idProduct=217
could I bung one of these on >> http://www.futuremotorsports.com/HELIX-ORGANIC-FRICTION-PLATE-ST205.html (I know its not from the same manufacturer.)
If I measure the amount of meat left on the plate (plate surface to face of rivets) Would someone be able to tell how much life is left in the plate? I don't want to fit it and find out it was to come out again in 5k miles..
St205 WRC - Running sweet.
 Post subject: Re: Clutchmasters FX400
PostPosted: Thu Aug 01, 2013 3:26 pm
General consensus is down to just touching the rivet head is as far as you can safely go. When I did 18 months with slipping clutch ( needed careful use of right foot at the end ) I was just touching the rivet heads on wear.... That was 30000 miles worth. My fx300 only lasted 40000 miles before release bearing broke up, the centre plate however had wear around the damping springs. Not impressed by clutch masters plates !
Darryl
Darryl
PostPosted: Sat Aug 03, 2013 9:16 am
another option would be to pop a Helix clutch plate in there?
Stephen
1993 Carlos Sainz 2939, Forged, Apexi RX6B turbo with external wastegate. MOTEC M4, AFPR and 800cc injects. 3" exhaust, +1mm valves.ST205 cams. Rays 8.5" x 17". 205 rear subframe. Bilstein coilovers. 205 brakes.TRD diff
PostPosted: Sat Aug 03, 2013 10:50 am
would it fit and work together with the clutchmasters housing?
PostPosted: Sat Aug 03, 2013 12:30 pm
Yes
PostPosted: Sun Aug 04, 2013 11:40 am
I've heard good reports of the helix full face organic.
I would be wary of running a different pressure plate unless you've measured plate thickness and pressure for both types to check they're compatible. I once ran a competition pressure plate with standard friction plate (the shop sold it as a 'competition clutch' package) and the friction material split in half within a week due to too much pressure.
PostPosted: Mon Aug 05, 2013 5:32 am
Sounds like you had a mis-match of specifications?
A Helix 6 puck plate would suit your Clutchmasters housing?
They are circa £200.
I had an FX300
and hated it,
it wouldn't disengage drive til warm,
this was at less than a year old.
Actually bought a worn Helix clutch
and popped a new plate in together with new release bearing.
You can re-pad a 4-6 puck Helix for circa £70.
Have had 3 Helix units without issue up to 50,000 miles.
Stephen
PostPosted: Mon Aug 05, 2013 11:21 am
Ok, so what are my options (cheap please)
If measurements are too tight etc, can I not use a spacer of some sort to space off the housing to reduce the the spring pressure?
edit: just thought about it and realised the the throw-out bearing would the partially engaged constantly if I did that...
Users browsing this forum: No registered users and 121 guests
