It is currently Sun Apr 28, 2024 10:50 pm
PostPosted: Tue Mar 26, 2013 12:56 am
Have been looking for months and posted up on all the relevant forums, not had any luck at all :(
Can anyone tell me where I might be able to find one? I will happily pay the going rate but I'm not willing to pay crazy money to get a new one imported.
Somebody help me or sell me the one you've for kicking around in your shed that you'll probably never fit!
PostPosted: Tue Mar 26, 2013 9:32 am
Have you tried the usual breaker suspects? I got a new Caldina side feed from Mr. T for £350 which I didn't think was too bad. Try fabricating one for that money and it wont be as robust as a cast OEM item. I do have a spare one including a TB which I picked up from Tim at TB Developments or Mark Mills a while ago so they do turn up from time to time.
PostPosted: Tue Mar 26, 2013 9:53 am
Really, is that all they cost from Toyota? I thought they'd be a hell of alot more than that seeing as they often sell for £300 second hand? Will try giving my local dealership a call.
Yeah have tried messaging various breakers who have Caldina parts for sale, but none of them want to sell a manifold without an engine :(
PostPosted: Tue Mar 26, 2013 9:55 am
P.S. sell me your spare one, pretty please ;)
PostPosted: Tue Mar 26, 2013 11:19 am
Does the ST205 throttle body fit straight onto the Caldina manifold?
PostPosted: Tue Mar 26, 2013 12:37 pm
Think I might have finally located one with a breaker - should I get the throttle body as well or do you adapt the st205 one or something completely different? St205 one would have the cable pull from the wrong direction wouldn't it?
PostPosted: Tue Mar 26, 2013 12:42 pm
In the absence of knowing - I would get the throttlebody if I were you. You can't go wrong then.
PostPosted: Tue Mar 26, 2013 12:46 pm
you should use the ST215 TB, the ISCV part is slightly different so you get no seal between manifold and TB, if you arent able to get a TB
i can offert you a ST246 one which fit the flange but has no ISCV (is directly fitted to the manifold on the ST246)
PostPosted: Tue Mar 26, 2013 12:54 pm
That's great, cheers Greetz :)
Has anyone ever done a decent write up on installing the Caldina manifold? Don't think I've ever seen anything.
PostPosted: Tue Mar 26, 2013 1:10 pm
Dave P has some info in his thread over on the OC.
It more of his impressions though rather than a 'how-to'.
PostPosted: Tue Mar 26, 2013 3:32 pm
Great cheers for the help guys, I have hopefully finally managed to locate one for £250 + post including the throttle body, sounds reasonable enough.
PostPosted: Tue Mar 26, 2013 3:41 pm
I would snap that up, especially given how long you have been searching for it!
PostPosted: Tue Mar 26, 2013 8:28 pm
The ST205 TB has a central IACV compared to the offset one on the Caldina TB. For a road car you really want the IACV for fine throttle control at small throttle openings. If you don't have this its likely the engine will 'hunt' at low rpm. This makes the car a real pain to drive in traffic. BUY IT NOW!
PostPosted: Wed Mar 27, 2013 10:35 am
re: fitting st215 manifold - depends on how long you can wait. I am going to be finishing up the engine ready to install soon with the st215 manifold.
- Can't use st205 TB, need st215 TB
- st215 manifold has less vacuum ports on it than the st205 manifold (i'm drilling/tapping two more in)
- can't easily link PS idle up valve to manifold. Hardlines are different. Need to customise something
- st205 IACV hard lines do not allow easy alignment to st215 tb, so need to find a solution
those are the areas off the top of my head. Can provide more info when I'm looking engine again, but not for, maybe, a month..
GT Four Adovansu
PostPosted: Thu Jun 06, 2013 9:33 pm
Anyone still looking for a Caldina manifold + TB? $300NZ ex freight (which I would imagine would be a decent price from NZ to UK).
Let me know over next couple of days
GT Four Adovansu
Users browsing this forum: No registered users and 183 guests
