It is currently Sun Apr 28, 2024 6:48 pm
 Post subject: tvis
PostPosted: Thu Aug 29, 2013 5:58 pm
Hi all, in current process of flowing the head on a st185. After the plenum and between head is I think what is called this. Now as I won't be needing it, I've removed the flaps and was wondering if removing the two sensors and all vacuum pipework would cause any issues?
Ecu is standalone if that helps.
Regards.
1998 mercedes E280- sold
 Post subject: Re: tvis
PostPosted: Thu Aug 29, 2013 6:25 pm
There are no sensors for TVIS, only the actuator, the resevoir and the valve. The other valve next to it is the TVSV which controls boost pressure (usually disconnected anyway when running aftermarket boost control).
PostPosted: Thu Aug 29, 2013 6:28 pm
Ah OK, just there are two plugs which I assumed were sensors right on the bracket where actuator and diaphragm are.
Users browsing this forum: No registered users and 166 guests
