It is currently Sun Apr 28, 2024 4:45 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: "La GrOsse" cooling mod
PostPosted: Mon Dec 20, 2010 2:21 pm
I want to share what MetalMachines® did for me according to the specification guidance.
Inspired by the 3S-GTE cooling post,TTE style, Sunny hard pipe, Alanv (OC.net) Corolla rad, ...
Basically a ST185 with gen.3 engine.
Previous set up : Golpher rad, 1.3 cap, TRD stat, air duct, alloy tap everywhere to avoid air leak, twin SPAL 11" pusher, 40% Ethyl / 60% water, washer bottle as unpresurised expansion tank, 13rows GB cooler, 13 rows engine cooler, 12mm spacer for end of bonnet.
Radiator and EVO8 IC arrangement
Front face without bumper
Alloy taping in air duct
Alloy taping engine side
Silicon hose (can see airbox and piping path)
Front bumper on, under signal light for oil cooler, we can see the cold air pick up too.
Alloy air duct pushing the bumper grid
New set up : Sierra RS500 rad, swirlpot, header tank, alloy hard pipe, polyamide degazing tube, 1.3 cap, TRD stat, 30% Ethyl / 65% water / 5% water wetter, 13rows GB cooler, 16 rows engine cooler (not complete yet), 12mm spacer for end of bonnet, air duct (not complete yet), alloy tap everywhere to avoid air leak (not complete yet), twin fan puller (ebay fan are craps, SPAL puller very expensive, have to decide ...) .
Rad on car between rail
More clearance between rad and turbo (hope it will keep away some of the heat soak)
Image Image
Custom swirlpot under construction
Swirlpot installed
Swirlpot clearance (able to install a 4" strait intake for a nice GT30 antisurged)
Image Image
Expansion tank after welding
Modified engine silentbloc to clear expansion tank
Expansion tank installed
Cold hard hose (and relocated alternator test fitting)
Cold hard hose complete and connected
I don't find a good position for the EVO8 IC as i don't want it to seat to low, i decide to source something else and go for a second hand aftermarket subaru one which fit nice behind the bumper grid
2nd hands Subaru part which explain the "Monster" on IC :lol:
New hot side piping for new IC
90° bend are avoid !
Hot side piping installed
New cold side piping too
I said i have a low track car, from lowest point of exhaust to floor there is 34mm, have tried to correct bump steer, sort something better than OEM but not perfect yet
Try to do it as short as possible
Relocate the IAT sensor too for accurate reading (and it works great)
Complete with polyamide degazing tub installed
Coolant system capacity is increased to 11.7L + 1.2L air (for expansion)
4th blank plug on the expansion tank if one day i want to run a post turbo alloy cooling tube (like the PAS one) and an electrical water pump.
On those last two pics you can see the beginning of the new air duct, with MetalMachines® logo pressed on, need times now to complete it and share more pics with you.
PostPosted: Mon Dec 20, 2010 2:29 pm
very nice indeed :-)
PostPosted: Mon Dec 20, 2010 2:43 pm
Great work!
PostPosted: Mon Dec 20, 2010 2:49 pm
wow! awesome work :)
PostPosted: Mon Dec 20, 2010 3:41 pm
5 of 5 stars 8)
PostPosted: Mon Dec 20, 2010 5:03 pm
I think the monster logo would be better suited to the RS500 rad. :lol:
Looks like an excellent setup, given me some ideas as I need to do something with my 185 cooling.
PostPosted: Mon Dec 20, 2010 5:08 pm
Oooh - info also required on yoru alternator re-location :-)
PostPosted: Mon Dec 20, 2010 8:51 pm
Very nice! 8)
ST185 CS #1845
PostPosted: Mon Dec 20, 2010 9:30 pm
does i ask you for the wall thickness of the water pipes?
PostPosted: Mon Dec 20, 2010 10:21 pm
Thanks all for the comment, i do it like this because of your knoledge sharing here and because this time i want to do it right with no more over heating issue.
I think there is 2 thing that can uprated this setup : an electric water pump and a triple flow design rad (which can be done on the "Monster" RS500 rad) but to be fair i think 105°+C is an old story now.
Sunny,
30 OD, 27 ID means 1.5mm
Oulet water ID is 27mm, we choose this pipe because of this
Don't control Inlet water ID but i think it is similar to Oulet
They are 1 piece part, heated and then hand bended
We machined an ally log for silicone 32mm link, 25mm long, 33 OD, 30.2 ID, and weld at each end.
Every thing have been leak tested under 4 bar and is leak free, i know i could use a formula 1 rad cap, pipe won't leak or go mad.
PostPosted: Tue Dec 21, 2010 10:16 am
WOW...very impressed.
A lot of thought gone on here, thanks for sharing.
PostPosted: Tue Dec 21, 2010 4:34 pm
many thanks
PostPosted: Fri Feb 18, 2011 10:17 am
Small Update
As i have change both rad and IC i need a new design AirDuct (it performed so well on the previous set up)
What it looked before any brainstorming with myself (:lol:)
This time IC is just behind the front bumper, the Airduct can't go from the rad to the bumper, but i have enought space between rad and IC.
After some cardboard template, i tTook some 1.5mm aluminium sheet and some foam sealant
Ended to this
We can see here that the foam sealant will take care of vibration and air leak, bottom is not completly pressed, top is not at all.
Now it is time to put back the IC, gap between rad and IC is 134mm, the aluminium sheet is 131 and foam sealant is 10mm thick each side.
You easily understand that fiiting the IC is a pita as i need to compress a lot the foam
A front view to see where air can pass to see the rad
My car is a 110% track car and my front CS bumper have suffer from gravel tap once or twice :roll: so is not in its best status, i decided to mod to "try to control" airflow
Cut the middle number plate holder, put 2 aluminium sheet each side of the IC (funnel shape) and some alloy tap
Poor Iphone quality
Some mat black paint on the sheet and of course some guard to protect everything (25mm gap from guard to IC)
Poor Iphone quality
Poor Iphone quality
I now need to complete the oil rad set up to share the end of the front ducting.
PostPosted: Fri Feb 18, 2011 11:51 am
Car Model: ST165
excellent :)
ST165 turbo 4WD
PostPosted: Fri Feb 18, 2011 1:25 pm
damn good work :-)
Users browsing this forum: No registered users and 173 guests
