Archers forged rebuild http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6434 |
Page 1 of 3 |
Author: | martinking6 [ Sat Mar 30, 2013 9:02 pm ] |
Post subject: | Archers forged rebuild |
Another forged build for you all to follow, this ones for archer Some of the probs found when stripping the engine from the car Locking nut covers missing on fig 8 nuts ![]() Split vsv hose ![]() Clips not fitted correctly ![]() Snapped power steering idle up steel pipework ![]() Power steering pump main pivot bolt missing ![]() Head removed ![]() ![]() Rocker cover underside ![]() Worn out clutch ![]() ![]() ![]() Martin |
Author: | martinking6 [ Sat Mar 30, 2013 9:08 pm ] |
Post subject: | Re: Archers forged rebuild |
Crank journals condition ![]() ![]() ![]() ![]() ![]() ![]() ![]() The crank timing pulley was seized on the crank and wouldnt come off so had to delicately slice the pully and then split it to get it off ![]() ![]() Martin |
Author: | martinking6 [ Sat Mar 30, 2013 9:14 pm ] |
Very poor bore condition ![]() ![]() The rusty section across the bore on the pic above is actually a crack ![]() The failed no.4 piston ![]() ![]() Martin |
Author: | jgtcracer [ Sat Mar 30, 2013 10:06 pm ] |
did the car come in because of engine failure or an upgrade? looks like a much needed engine build |
Author: | martinking6 [ Sat Mar 30, 2013 10:20 pm ] |
jgtcracer wrote: did the car come in because of engine failure or an upgrade? looks like a much needed engine build Ye it is a lad from scotland the engine failed on him 2 weeks after buying the car unfortunately Martin |
Author: | TrackToyFour [ Sat Mar 30, 2013 11:09 pm ] |
Looks like another ST205 which has been run on the smell of an oily rag ![]() |
Author: | jgtcracer [ Sat Mar 30, 2013 11:33 pm ] |
was there much oil in the sump when you drained it martin? Im gutted for the guy, hope he got it cheap knowing it was going to need work. Id def be contacting the seller just to vent my frustration at a poorly maintained motor |
Author: | dale [ Sun Mar 31, 2013 9:28 am ] |
gutted for the person, shocking and to be honest, it appears like Don says that its yet another person buying a st205 because they are cheap, then realising at the first service bill they cant afford to fix it so do it on the cheap or even better.... just dont at all. |
Author: | martinking6 [ Sun Mar 31, 2013 9:53 pm ] |
Matts cool he is under no illusions and has cut no corners, he has fully listened to my advise and gone with suggestions made. The engines actually rebuilt and back in the car, if I get other work done in time it should be another 4 saved on tuesday when I turn the key plenty more pics to come as well as more builds to show, got another 4 builds after this one including another stroker with offset ground crank and a linered build which will be interesting to share Martin |
Author: | martinking6 [ Sun Mar 31, 2013 9:56 pm ] |
TrackToyFour wrote: Looks like another ST205 which has been run on the smell of an oily rag ![]() Hiya don I had to replace the crank but thats all sorted now cheers, mike was showing me your build this weekend whilst he was over looks seriously impressive can`t wait to see it in the flesh ![]() Martin |
Author: | Sunny [ Sun Mar 31, 2013 9:58 pm ] |
Hi, is the crank between no.3 and 4? greetz |
Author: | martinking6 [ Sun Mar 31, 2013 10:32 pm ] |
Hiya The pics are of all the journals they were all marked up Martin |
Author: | Sunny [ Mon Apr 01, 2013 12:44 pm ] |
Hi, sorry, used the wrong word, i mean crack i would guess it is between chamber no2 and 3 thats a point of where a water channel is running between both greetz |
Author: | martinking6 [ Mon Apr 08, 2013 11:29 pm ] |
Sunny wrote: Hi, sorry, used the wrong word, i mean crack i would guess it is between chamber no2 and 3 thats a point of where a water channel is running between both greetz Hiya To be perfectly honest I can`t remember now will have a look in the unit see if I still have the block Martin |
