4evacelica work http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6458 |
Author: | martinking6 [ Sun Apr 07, 2013 6:37 pm ] |
Post subject: | 4evacelica work |
As promised and long overdue I am going to do a little thread on repairs done now and in the future Steel driveshaft guard bent well out of shape Engine out Cracked exedy clutch friction plate Rear and front crank seal starting to leak Power steering pump main pivot bolt missing Martin |
Author: | Insanity-74 [ Sun Apr 07, 2013 7:28 pm ] |
Post subject: | Re: 4evacelica work |
Whats your opinion on Exedy clutches? |
Author: | Sirius [ Sun Apr 07, 2013 7:32 pm ] |
I am forming an opinion based on the picture! |
Author: | martinking6 [ Sun Apr 07, 2013 7:42 pm ] |
Ive never had any issues with exedy clutches apart from there a bit smelly if slipped but theres more to this scenario as when it has been fitted by whoever the master cylinder hasnt been adjusted to compensate for the new clutch so the clutch has been dragging badly which won`t of helped the situation it was apparently very bad to engage and change gears so maybe that has contributed to the failure Martin |
Author: | martinking6 [ Sun Apr 07, 2013 7:56 pm ] |
Engine base timing out by 1 tooth on each of the cam pulleys Damage to lower timing belt cover Cause of the damage the guide plate for the timing belt is bent so has been cutting through the cover Martin |
Author: | martinking6 [ Fri Jun 28, 2013 12:15 am ] |
Refurbed head New cam seals installed Martin |
