Gauges http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6502 |
Page 2 of 3 |
Author: | TrackToyFour [ Fri May 10, 2013 3:45 pm ] |
Post subject: | Re: Guages |
According to the Defi-Shop the Defi Link Display is no longer made . Anyway it doesn't do boost so doesn't tick all your boxes although I suppose you could always buy secondhand off fleabay if you wanted one. If I were you I'd work out how you want the dash etc. to look then go through what's available. It's very easy to end up with a messy looking interior so time spent planning is well worthwhile. |
Author: | Loosey [ Fri May 10, 2013 5:30 pm ] |
Don I agree whole heartedly. This is all proving to be very taxing. . . . decisions decisions! I have found the following, but none of then really ‘float my boat’ http://www.ebay.co.uk/itm/TRIPLE-GAUGE-DIAL-POD-HOLDER-52MM-2-Single-DIN-Boost-Oil-Fuel-Pressure-Volt-/271093967570 Don't think this is going to look very classy in 'the flesh' http://www.ebay.co.uk/itm/Single-gauge-pod-for-Celica-GT4-ST205-ST202-custom-made-52mm-or-60mm-gauge-pods-/251264772310 A single gauge which would be better than the single mount I already have but doesn't solve the oil gauges issue! This is a possibility as a starting point but would need some 'tweaking' . . . I was hoping to avoid the 'Blue Peter' approach! http://www.nexxia.co.uk/pics/FP-007.jpg |
Author: | TrackToyFour [ Sat May 11, 2013 10:55 am ] |
Post subject: | Re: Gauges |
I looked at that 'zig-zag' triple gauge panel when I was evaluating options a while ago but wasn't convinced of the aesthetics. 52mm dials are a really tight fit in a DIN panel particularly if you take the outer bezel/trim into account. It might work, if you have excellent Blue Peter skill sets You can get gauges smaller than 52mm diameter but the range is quite limited so I decided not to go down that route. Have you decided on analogue or digital yet? |
Author: | Muddy Water [ Sat May 11, 2013 12:06 pm ] |
The 'zig-zag' triple gauge panel does not fit properly in the dash (at least not nicely as it relies on "clipping" in). Also the gauges are a tight fit. The blank panel is a reasonable fit but as previous the gauges are a tight fit. You also need, as Don mentions, good Blue Peter skills. Tried both options and wasn't convinced/happy with the final outcome of either. The best "OEM" type option, albeit expensive, is the 3-Din Defi unit. |
Author: | Loosey [ Sat May 11, 2013 10:13 pm ] |
Muddy, agree the 3-Din Defi unit is the best solution but it doesn't support the gauges I need I am going to keep looking the solution must be out there! Don, not made my mind up about analogue or digital, I'm just not ruling anything out! |
Author: | Loosey [ Tue May 21, 2013 10:17 am ] |
OK so I have found a possible solution (I’m currently getting Mr Grumpy to look into feasibility because I really don’t understand most of this!!! LOL) I have stumbled across these: http://www.auberins.com/index.php?main_page=index&cPath=5_21 From the blurb it sounds like they can be setup for almost any type of monitoring and can use almost any sensor (theirs or A.N.Other) They appear to have an alarm function and also the ability to ‘shut off’ or ‘trigger’ other things when set limits are reached/exceeded. Whilst it isn’t expandable like the Defi, I am still not convinced that I need any more than Oil temp / pressure and one other (probably water temps) but due to their size, I can easily fit 3 in a single DIN blanking plate, possibly more if I so desired. Anyway, as always thoughts on a post card . . . . !! |
Author: | two_OH_five [ Tue May 21, 2013 11:23 am ] |
JP or indeed I have samples of those |
Author: | Loosey [ Tue May 21, 2013 11:44 am ] |
Do you have them fitted? Do they work? Thoughts/reviews please! |
Author: | two_OH_five [ Tue May 21, 2013 1:26 pm ] |
Mine, in typical me style, are fitted to a drawer somewhere. Probably never to be found again I did fire it up and looks wise it was ok From memory 4 would fit in a single din as two stacks of two JP and I both jumped on one as the cheapest way of measuring EGT I think I had figured out that you could fit a pair of these flanked by spa twin needle gauges to give 6 displays in a single din unit My problem with such a setup is information overload and poor positioning so for me the Defi Display in line of sight is a better proposition When Chris pulls off the central logger with small remote display that would be my choice Or, if you want to be real radical replace the double din with a 7" tablet and run torque for gauges and another app for media using the headphone output to drive external amps This was my plan for the Beemer but I can't find a decent way to control the tablet as it's too far away for comfortable use in an idrive dash |
Author: | Sirius [ Tue May 21, 2013 1:26 pm ] |
I really like those gauges and looked into them a lot before making my final decision. I decided against them for two reasons (neither of which are probably relevant to you) the first was that with measuring 7-8 parameters I thought the dash would look very busy and possibly a bit 'Back to the Future'! Secondly the gauges don't have a label on to say what they are which would mean stiky labels, fine if you only have 3 or so probably a pain if you had 8. If I was only using 3 I think I would hide them away in a DIN sized pocket with a door on - that way you can have the door open when interested and hide them away when not. |
Author: | Sirius [ Tue May 21, 2013 1:31 pm ] |
two_OH_five wrote: Or, if you want to be real radical replace the double din with a 7" tablet and run torque for gauges and another app for media using the headphone output to drive external amps This was my plan for the Beemer but I can't find a decent way to control the tablet as it's too far away for comfortable use in an idrive dash I havent looked into this Torque app - can it work with cars that dont have OBD2 for gauges etc? |
Author: | two_OH_five [ Tue May 21, 2013 2:47 pm ] |
Not until Chris is finished with his box Mike. It uses OBDII, primarily over Bluetooth using an ELM327 plugin adapter |
Author: | Loosey [ Tue May 21, 2013 3:47 pm ] |
Quote: I thought the dash would look very busy and possibly a bit 'Back to the Future'! And your problem with that is . . . ?? |
Author: | Nibbles [ Tue May 21, 2013 6:37 pm ] |
I thought you didn't like digital, or am I mixing you up with someone else ? |
Author: | TrackToyFour [ Tue May 21, 2013 7:16 pm ] |
......and I thought you wanted a boost gauge? AFAIK these mini digi gauges are temp and pressure only? |
Page 2 of 3 | All times are UTC + 1 hour |
