BLITZ ACCES ECU ON ST185 CS http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6843 |
Author: | robergt4 [ Mon Nov 18, 2013 4:35 pm ] |
Post subject: | BLITZ ACCES ECU ON ST185 CS |
Hello Is it possible to mount a blitz ecu of st185 Alltrack in ST185 cs? If the watercooler ecu is disconnected , continues to operate the pump? Causes this code? Breakdown and check light on? Greetings |
Author: | darrylp [ Tue Nov 19, 2013 11:11 pm ] |
Post subject: | Re: BLITZ ACCES ECU ON ST185 CS |
It won't be mapped to measure the air flow through the larger AFM that the CS/rc have. So no, don't use it unless you down grade the AFM to match the normal sized one in the st185 -- Darryl |
Author: | XLarge [ Sun Nov 24, 2013 12:06 pm ] |
It will not even start. A mate of me bought a Blitz Access for his CS and it didn't start with it. Than he found out that it was a ECU for a normal ST185. The AFM of the CS/RC is not only have a bigger diameter, it also have a different connector with one pin more. |
Author: | ST185pinjo [ Tue Nov 26, 2013 4:09 pm ] |
What fuel do you use? |
Author: | robergt4 [ Wed Nov 27, 2013 2:42 am ] |
98oct |
Author: | XLarge [ Wed Nov 27, 2013 7:16 pm ] |
I have a Mines ECU in my CS. Usually I use 102 octane fuel. Makes a uge different to 98 octane. |
Author: | robergt4 [ Wed Nov 27, 2013 10:21 pm ] |
XLarge wrote: I have a Mines ECU in my CS. Usually I use 102 octane fuel. Makes a uge different to 98 octane. In Spain only 98 oct max. ![]() |
Author: | XLarge [ Wed Nov 27, 2013 11:28 pm ] |
I life in Germany. Most Shell stations sell 100 octane here and the bigger Aral stations have 102 octane fuel (both for an insane price) . |
