Jason's 185 build http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6934 |
Author: | Sirius [ Fri Feb 07, 2014 11:37 pm ] |
Post subject: | Re: Jason's 185 build |
Nice build - one benefit of that oil everywhere is there does not seem to be any signs of rust anywhere! ![]() |
Author: | TrackToyFour [ Sat Feb 08, 2014 10:58 pm ] |
Nice photo diary Jason ![]() Engine bay cleaned up well. Looks like it has survived well under the oil film. I see you have painted the alternator and inlet manifold. What type of paint did you use? Good luck with the project and keep us posted on your progress. |
Author: | clu7ch [ Sun Feb 09, 2014 5:39 pm ] |
Thanks for the responses guys. All I used to paint the parts was over the counter duplicolor paint. Nothing special really. The reason the paint job turned out so well is due to the sandblasting and proper prep work. I am usually in a hurry to paint and it doesn't always have the best outcome. I took my time on these and I am quite happy with the results. The photos are a bit deceiving however. Since the paint has had time to cure it has turned a more gunmetal grey color. |
Author: | clu7ch [ Mon Mar 03, 2014 9:24 pm ] |
Update: Picked up my motor from the machine shop over the weekend. Unfortunately it was way too cold over the weekend to spend time in the garage working on it (-46 c with the wind chill). By the end of next weekend I should have made some serious progress on the build. Will update then. |
Author: | Sirius [ Mon Mar 03, 2014 10:16 pm ] |
Ouch - that's pretty cold! Rain and flooding has been the problem over here in the UK lately. Looking forward to seeing pics of the motor. |
Author: | MrDB [ Tue Mar 04, 2014 2:57 pm ] |
Great progress so far. Worth checking the steering rack mounts for cracks while you have access. Easy fix if they have cracked and engine out but nightmare with engine in. Quick tips : Undoing the crank bolt. 1) Easy way remember to crack it while still in car use gearbox and brakes to stop engine turning or last resort flick with starter motor. 2) if you forget (1) ![]() Just finished my build and had the nervous first start but all good so far ![]() |
Author: | Sirius [ Tue Mar 04, 2014 3:39 pm ] |
MrDB wrote: Just finished my build and had the nervous first start but all good so far ![]() Where are the pics!?! ![]() |
Author: | clu7ch [ Tue Mar 04, 2014 5:57 pm ] |
MrDB wrote: Great progress so far. Worth checking the steering rack mounts for cracks while you have access. Easy fix if they have cracked and engine out but nightmare with engine in. Quick tips : Undoing the crank bolt. 1) Easy way remember to crack it while still in car use gearbox and brakes to stop engine turning or last resort flick with starter motor. 2) if you forget (1) ![]() Just finished my build and had the nervous first start but all good so far ![]() Yea checking the steering rack mounts was one of the first things I looked at once the motor was out. Thankfully they seem to be in good condition. We had that issue with the mounts on my buddies CS RC 185. We ended up needing to weld up a sizeable crack on one of his mounts. Normally I would have just tried to remove or at least loosen the crank bolt with the engine still in the car...however it totally slipped my mind haha. Too excited with the project I suppose ![]() I would also be interested to see some photos from your build. Do you have a thread? |
Author: | Muddy Water [ Mon Mar 10, 2014 9:08 pm ] |
Interesting point about the ARP studs and the oil pan issue. I had exactly the same issue with my build and a Moroso Oil Pan. A modification (cut out and weld new piece in providing clearance) to the oil pan was the solution I went with. |
Author: | clu7ch [ Sun May 11, 2014 11:03 pm ] |
Well today I got the car running and took it for it's maiden voyage ![]() I will have lots of pictures to post up tomorrow |
Author: | TrackToyFour [ Tue May 13, 2014 9:09 pm ] |
Nice update ![]() Are you running the Crower 264 cams off the standard ECU and injectors? |
Author: | clu7ch [ Tue May 13, 2014 9:12 pm ] |
TrackToyFour wrote: Nice update ![]() Are you running the Crower 264 cams off the standard ECU and injectors? For this season yea. Next year I will be looking at an ECU and injectors and a different turbo setup |
