http://www.gt4dc.co.uk/forum/
Apexi PFC
http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6985
Page 1 of 3
Author:  Nibbles [ Thu Mar 06, 2014 8:43 pm ]
Post subject:  Apexi PFC
Trying to help someone diagnose a PFC problem. I think he's registered on here & waiting for activation.
Apperently it's basically running but won't drive the idle solenoid.
Also, the bat volt on the commander is reading 0.
My thought on the idle may be the throttle closed switch not engaging, but puzzled by the bat volt as the ECU must be powered to run the engine & drive the commander.
Any help from the experienced PFC users would be appreciated.
Author:  Sirius [ Thu Mar 06, 2014 9:26 pm ]
Post subject:  Re: Apexi PFC
I haven't seen any legitimate new registrations, please ask him to drop me an email if he has tried.
There is so much spam its sometimes difficult to tell who is real and who is not!
No ideas on the problem - seems very odd.
Author:  two_OH_five [ Fri Mar 07, 2014 12:56 am ]
I've always got the datalogger if you get stuck. Trying to remember if idle is in the sensor list. Not ringing any bells
Author:  Nibbles [ Fri Mar 07, 2014 2:05 am ]
I seem to remember when we were playing with Phil's we could view whether the throttle closed switch was made.
Author:  Nibbles [ Fri Mar 07, 2014 1:34 pm ]
I'm wondering if the voltage is measured from the permanent live and that could be missing.
Author:  Diceman [ Fri Mar 07, 2014 1:57 pm ]
I believe it is shown on the hand controller as "IDL" or suchlike and is in the sensor check section.
0.0V is an odd one, I can only assume there are 2 different locations/wires and one has an issue.
Author:  Nibbles [ Fri Mar 07, 2014 4:36 pm ]
There is a permanent live and 2x switched live which are normally connected together in the standard ECU, often only 1 is wired.
I gather it's from an MR2, just waiting to see which revision it's from as early ones have different idle solenoid wiring.
Author:  Tombrady [ Fri Mar 07, 2014 5:50 pm ]
Hi folks it's myself who has the problem. Big thanks to Chris for starting the ball rolling and all the replies. I have asked the seller which Rev it was from today. I really hope it is the wrong rev and it's just me jumping the gun and assuming all SW20's from the MR2 turbos were the rev3 3sgte.
Here's the serial number
Author:  Gary ST165 [ Fri Mar 07, 2014 6:05 pm ]
Tom & Chris
I note it doesn't say AP Engineering on the sticker, but if you unscrew the lid off the ecu, it will say AP Engineering on the board if it is for the rev2 sw20/sw21 3sgte.
http://www.imoc.co.uk/forums/viewtopic.php?p=1375458
also...
http://gt4dc.co.uk/forum/viewtopic.php? ... ght=#43199
Diceman wrote:
hmmm,
quote from internet...
"There are two distinct serial number schemes used in the PowerFC model #'s.
First generation is
YYMM-XXXX
Where;
YY is the build year
MM is the month
XXXX is the unique item #
Second Generation is
###-XXXX
Where ### is the batch build number, so 000 or 010 or 020 (ie batch build 010)
AP Engineering units are;
YY# XXXX
or
A XXXX
XXXX is the unique item # "
Are we sure it is an early unit?
Author:  Tombrady [ Fri Mar 07, 2014 6:21 pm ]
Ok two photos of its innards, one of the version on commander.. what does this mean then guys?
Author:  Gary ST165 [ Fri Mar 07, 2014 6:53 pm ]
yours is a 2nd generation power fc for the rev3 sw20 3sgte
i have yet to google what is the significance of FC COMMANDER2 Ver 8.13..
Author:  Tombrady [ Fri Mar 07, 2014 7:08 pm ]
Awesome Gary. Big thanks! So we can safely say it's the right one for my st205 bar the cc pump & sensor.
Author:  Gary ST165 [ Fri Mar 07, 2014 7:25 pm ]
yep...that's what my research leads me to believe.
curious, what did the seller say about the fault and the model , have you got a link to the old for sale advert etc
From what i can see its got the same chip andn stickers on the board as my old rev3 sw20 power fc
Author:  Tombrady [ Fri Mar 07, 2014 7:33 pm ]
It was bought from an eBay listing but I paid outside of eBay via goods on PayPal which until I emailed him about the issue last week was still in my watch list. Didn't say much except it was from a working Celica that has now been broken for spares. I have emailed the seller today to ask which rev/model it was they broke.
Author:  Tombrady [ Sat Mar 08, 2014 3:44 pm ]
Going to try it on a 185 tomorrow and another 205 which should help narrow the problem down a little. Then I'll try the voltages on each pin out with the blitz ecu at idle and write them down and do the same with the apexi if need be.
