Craig Davies EWP for charge cooler ? http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=7092 |
Author: | XLarge [ Thu Jun 12, 2014 8:08 pm ] |
Post subject: | Craig Davies EWP for charge cooler ? |
My charge cooler pump died on a short circuit and caused a burn to the car´s chassis loom. Was a overhauled pump I put in last year. Now I´m fed up of peeing, rumbeling ( the original pump of my car) and short circuited ( the replacement ) pumps and thinking about to switch over to a Craig Davies electrical pump. Did anybody used one of this pumps therefor ? Any opinions ? Oh, I forgot to say: Switching to a FMIC is no option. ![]() Greetings, Eric |
Author: | Sirius [ Thu Jun 12, 2014 8:41 pm ] |
Post subject: | Re: Craig Davies EWP for charge cooler ? |
I think this would work fine. ![]() There are a few options for refurbished pumps over here in the UK if you wanted to try another. Although with the loom damaged an aftermarket one may well be a lot easier to sort out. |
Author: | XLarge [ Thu Jun 12, 2014 9:10 pm ] |
I repaired and modified the loom today. The pump was running on switched power already as I have a ST205 engine in my ST185 CS with a late spec MR2 turbo ECU from Mines. The guy who made the loom therefor connected the pump on switched power without a fuse, only god knows why. I extended the loom while repairing it. The switched power leed now switch a relais that switch permanent power from the fuse box, including a own fuse to the pump. Only thing is that the fuse blow instand, caused by the short circuit pump. ![]() A refurbished pump from the UK will cost a lot of shipping to get here to Germany, to sent my old one back will double the shipping and I don´t think that I will get a refound for the burned pump anyway. So I think to buy a EWP here will cost only a bit more and will be a upgrade compared to a refurbished standart pump. I´m only confused about which one to buy. |
Author: | Sunny [ Sat Jun 14, 2014 10:44 am ] |
Hi, http://www.jabscoshop.com/marine/pumps/ ... riming.htm fits the (st205) bracket p&p greetz |
Author: | XLarge [ Sat Jun 14, 2014 9:20 pm ] |
Way too expensive, sunny. The EWP80 from Craig Davies makes 80 l/min too and costs 209 Eur incl VAT. Making a bracket isn't so much work to do. |
Author: | Sunny [ Mon Jun 16, 2014 9:48 pm ] |
Hi, sry, aint had a look on the price, iirc i bought the pump for around 200€ years ago greetz |
Author: | XLarge [ Sat Aug 09, 2014 10:11 pm ] |
It ended up by buying the EWP80. Fitted it to the car today: The pump is very slim, but got big connections so I needed adapter hoses I luckily found on eBay. Started with unpacking the parts and remove the burned pump: ![]() Needed some time of brainstorming to find the right position for the pump and making a custom bracket for the pump: ![]() Only needed to replace the power connector by the one from the burned pump and bolt the pump into it´s new place: ![]() The underside cover fits barely and I´ll have to think about it to cut it out if the pump makes too much noise as the cover touching the pump, but I´ll decide this after a test drive I didn´t done. |
Author: | Sunny [ Mon Aug 11, 2014 1:17 pm ] |
Hi, looks good, you can also try to heat the plastic with a blow-dryer and bend it if you have the chance to get enought space greetz |
