It is currently Mon Apr 29, 2024 12:06 pm
PostPosted: Thu Jul 16, 2015 10:27 am
Hi Guys,
looking for recommendations on a downpipe. I see Aussie downpipes getting quoted as the best but i am struggling to find a supplier.
I`ve found this one on Ebay
http://www.ebay.co.uk/itm/TOYOTA-MR2-TURBO-CELICA-ST205-DECAT-DE-CAT-DOWNPIPE-/310228623628?pt=LH_DefaultDomain_3&hash=item483b11210c
It seems to be a popular seller but has anyone got one fitted or can point me in the right direction for a decent replacement thats pretty straight forward to fit,
Thanks
PostPosted: Thu Jul 16, 2015 9:43 pm
Berk down pipe is available from www.gtschris.com
Recent reports suggest the pipe benefits from a bit of a tidy up internally with a die grinder or similar. I've been pleased with mine.
PostPosted: Mon Jul 20, 2015 1:16 am
You have trouble to find a seller that still offers Aussi products because Aussi went out of business some years ago.
Cheap eBay downpipes aren´t the best. Some have not enough room in the wastegate area so the wastegate flap can´t open fully.
After my Aussi downpipe cracked two times I replaced it with the one from Berk. Finish of the welds inside the pipe is real horrorbly and may benefit from grinding the welds down befor installing. I´ve decided against as I bought the coated version and didn´t want to destroy the coating.
PostPosted: Wed Aug 19, 2015 8:55 pm
iv seen the berk decat pipes and the welinding is not the best and the finish is rely bad :( here are some photos of the inside and the end, all so the flanges were both bent and need linishing to get them flat, all decat pipes you can get are made in china now,
not very good and there not cheap, this is why I have started to look at making them
so started with a Jig to make the decat up on
bottom parts of the Decat done
top half done
all ready for flexi
flexi fitted in all nice
the fun bit
all done
all cleaned and polished
the inside of the pipe
so first test fit of the flexi decat
all good so far but it may need a tweak hear and there, till im happy
BRD Page
http://www.brooks-brd.co.uk/
https://www.facebook.com/Brooks.Racing.Dev
PostPosted: Wed Aug 19, 2015 11:16 pm
Looks like the clearance for the bolts / stud/nut is marginal on the underneath at the top and the top one at the bottom.
Every downpipe I have ever seen has this, given that you have gone to the trouble of making a jig etc it would be nice to see this got right.
PostPosted: Wed Aug 19, 2015 11:58 pm
don't know if you can see but we have made it so you can get the top bolt on the bottom flange in and given more room on the top bolt on the top flange but as I said were still working on it to make shore it is right and will have the bottom V bracket and proper gasket with it not cheap ebay gasket
BRD Page
Users browsing this forum: No registered users and 188 guests
