It is currently Wed Feb 21, 2018 10:27 am
 Post subject: St205 Brake Lines
PostPosted: Wed Jun 14, 2017 9:39 am
Had a look at the brake lines on my st205 and they need replacing
Are there any uprated stainless braided lines available?
Or is it a matter of replacing with oem lines.
Anyone have any info?
Let me know.
Thanks
S..
T
 Post subject: Re: St205 Brake Lines
PostPosted: Wed Jun 14, 2017 1:04 pm
The front lines are a complex multi-section affair and there have been bad reports of aftermarket braided lines not being particularly suitable. Best bet is probably oem - http://www.tcbparts.co.uk/ unless your local Toyota dealer can supply
PostPosted: Wed Jun 14, 2017 2:03 pm
My preference is oem regardless. From past experience of braided, the braiding hides the condition of the actual pressure hose underneath so when they go, there's no warning.
Specific to the 205 front - there have been many reports of aftermarket braided hoses failing due to the extreme twisting involved with the superstrut. If I was forced to go braided I would look at the Fensport ones as I know their original ones had failures and they issued a recall to exchange for a new design. This probably means they have researched and corrected the issues, especially knowing their good reputaion.
PostPosted: Wed Jun 14, 2017 2:59 pm
As above - just get OEM lines from TCB. Don't forget the little 'link' piece for either side of the fronts.
PostPosted: Thu Jun 15, 2017 9:36 am
Thanks for the reply's chaps.
That's what I thought that oem would be best.
Will be spending more money with TCB soon.
It never ends...lol
S
PostPosted: Sun Jun 18, 2017 12:51 am
if it helps iam using jspeed lines, you can get them in japan
you will not find a good brake line outside of japan instead of toyota oem
https://www.rhdjapan.com/j-speed-stainl ... elica.html
