It is currently Fri Apr 19, 2024 3:43 pm
 Post subject: Pedals
PostPosted: Thu Jan 18, 2018 6:01 pm
On an ST205, anyone attempted to change the pedals over to something a bit more sporty. The 23 year old rubber ones do make the interior look a bit run down! Are people using covers or replacing them altogether?
 Post subject: Re: Pedals
PostPosted: Fri Jan 19, 2018 12:18 pm
From what I have seen Toyota GT86 ones look like a direct replacement. They are the same as ones used on sporty MR2's and IS200's. I am sure if you could find the part numbers you could get them brand new.
PostPosted: Fri Jan 19, 2018 2:35 pm
I was hoping to replace just the pedals rather than the whole arm etc. is that what you mean? I might actually go out now and just check see if I can get em off!
PostPosted: Fri Jan 19, 2018 4:13 pm
Well the rubber does come off on clutch and brake but gas is attached. So possible they might swap over...
PostPosted: Sat Jan 20, 2018 3:27 pm
Accelerator should come off as well. Might be screwed on. Both MR2 and IS200 should use similar assembly. GT86 looks similar as well.
PostPosted: Sat Jan 20, 2018 8:08 pm
Sorry for the hijack, but would these fit a 185 too?
PostPosted: Tue Jan 23, 2018 10:28 am
Have just ordered some new rubber ones for now (fiver off ebay) will look better than the 20 year old ones on there currently! Probably need to investigate a bit more what options there are in terms of drilling and fitting aftermarket ones.
