503E Info thread http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=1043 |
Author: | Diceman [ Tue Jun 13, 2006 1:59 pm ] |
Post subject: | 503E Info thread |
Found this whilst perusing my usual keywords on ebay http://makeashorterlink.com/?S29F6104D Detailed spec:- TRD 503/3SGTE 2.1L Specially casted cylinder block (503 BLOCK), forged pistons (single compression ring), billet 4340 TRD chrome moly rods (H beam), billet steel crankshaft, billet steel camshafts, 3 stage dry sump with custom oil pan, billet aluminum cam caps (T6061), shim under bucket valve train, steel head gasket, all high-grade custom fasterners, adjustable TRD cam gears. SPECIAL: The head is reversed, intake on the right when facing the front of the engine. The exhaust is on the left when facing the front of the motor. Original 3SGTE is totally the opposite. Spec List: Detail Bore x stroke (87mm x 88.3mm), compression ratio 9.5:1, intake cam specs 250* duration @.050; lift 13.5mm (lobe center 112*), exhaust cam specs: 262* duration @ .050; lift 14.3 mm (lobe center 112*) Intake valve diameter 35.5mm/valve stem 4.45mm, exhaust valve diameter 29.0mm/valve stem 5.45, valve train buckets 33mm outer diamter/31mm inner diameter/24.65mm total height/8.13mm shim diameter/4.25mm shim height. Steel head gasket: 2mm Accessories: Alternator, crank pulley, timing belt, dry sump belt, alternator belt, intake & exhaust manifold gaskets, crank & angle sensors. Does anyone else have any info on this rare beast? Anyone with too much money want to buy it for analysis? |
Author: | krude [ Tue Jun 13, 2006 3:17 pm ] |
That e-bay ad says 4th Gen?? ![]() Found something here http://www.retrotech.co.nz/toydohc.html (Also some good G/B info here http://www.retrotech.co.nz/toybox.html ) Something else here but cant seem to find it just the cached search hit "Engine race toyotaToyota introduces new Race Engine designed by TRD and Ed Pink Racing ... The bottom end of the Toyota 503 Race engine is patterned after the 3T engine. ... 5002.u97sk.info/ - 33k - Cached - Similar pages " http://www.raceweb.co.za/technocraft.htm http://www.cardomain.com/ride/804063 Gives a pic of a 4AGEs engine which states "The individual throttle bodies look like they came off the fabulous 503 race engines. Think about it, no Toyota factory RACE Engine had 5 valves per cylinder!! Yamaha- who works with Toyota on cylinder head design (and manufacturing), have been a very avid pioneer and supporter of the 5-valve design. The short-lived Yamaha Formula 1 engines had 5 valves per cylinder. In terms of maximum valve to surface area- the 5 valve design cannot be beat- theoretically and geometrically." http://www.clublexus.com/forums/showthr ... adid=67290 "Well yamaha made the head for the 3SGTE and that is one of the most reliable and powerful engine toyota has ever made. including the 503 race engine they used in the 800-1000HP IMSA GTP cars." http://www.celicatech.com/forums/printthread.php?t=5836 Some more stuff by a poster at the bottom (The pics of the red cars engine look good) |
Author: | krude [ Tue Jun 13, 2006 3:28 pm ] |
Some more info, nothing concrete tho http://forums.melbccr.com/showthread.php?t=43632&page=2 "on the topic of the TRD 503E 3SGTE engine. its what Rod Milen uses for his 1000HP Celica at pines peak. the 503E is a pure bred racing engine which has absolutely nothing to do with the 3S-GTE. there is only about 5 - 10 503E's in the world. Rod Millen has at least 90% of them. im sure you could buy one if you called Toyota Team Europe in Germany and asked them to make you one." http://www.google.co.uk/search?hl=en&q= ... gine&meta= |
Author: | two_OH_five [ Tue Jun 13, 2006 7:57 pm ] |
*Runs off to check 503e pictures First I've heard of a reversed cylinder head! Oddly enough there was a brief picture of one on SKY today when they had a quick run round said Rod Millen Pikes peak celica on "Rides" (I think). It was something to do with his son Rhys buildind a car I've seen that engine a couple of times in the past on eBay $4k seems like a lot of money for <1000 miles of motoring which is, I guess, why it's never run in a car Nice looking dry sump kit though |
