http://www.gt4dc.co.uk/forum/
oem springs rates
http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=2313
Author:  datajon [ Wed Mar 12, 2008 11:36 am ]
Post subject:  oem springs rates
Reading taken from st205 front & st185 CS.front & rear.
Please note all springs still had good amount of paint, which mean they were not totally knacked ..
I have the data table if need can post up, just remember that this is my handy work, not something stolen from another site.
Author:  two_OH_five [ Wed Mar 12, 2008 12:01 pm ]
Hmm,
Interesting info Jon, thanks for sharing. I'll bookmark this somehow or other to preserve the info
Looks like 185 springs might be a good upgrade over stock 205 fronts :D
Author:  two_OH_five [ Wed Mar 12, 2008 12:07 pm ]
Now making an appearence in the post wiki
http://www.gt4dc.co.uk/website/workshop/pwiki.php
under the title Suspension Information
Hopefully any other tech info can be added to this over time to build up a nice library :D
Author:  Kris [ Wed Mar 12, 2008 1:16 pm ]
DJ - do you have a kg/mm figure for the above springs?
I feel that this isn't a direct comparison of the actual affect of spring rates between the 2 cars since the 185 has the conventional McPherson Strut and the 205 has Superstrut...
Will be interesting to see the spring rates for 205 rears :)
Author:  Diceman [ Wed Mar 12, 2008 2:02 pm ]
What really surprises me about this info is how linear they are for supposedly progressive springs.
spring rate based on 50mm deflection =
St205 front - 2.45 KG/mm
St185 front - 2.52 KG/mm
St185 Rear - 2.2 KG/mm
So very low compared to the 10KG/mm TRD coil-overs!
I have had a play around fitting std st185 & st205 springs to the others struts and top mounts a couple of years back and IIRC the rears did not sit right at all - can't remember about the fronts. (maybe I didn't try them!)
Good info DJ, a lot more technical than my stick a sack of spuds on the spring and measure deflection to see which deflected most.
My results suggested that ST205 springs were stiffer ( lookinga t your graph at circa 25KG = sack of spuds this would just be the case).
Interesting that ST185 has greater rising rate of spring as you get more load.
I intended on measuring the coil wire dia, coils per inch and the oustide of coil dimension to calculate the spring rate. Unfortunately this was shot to pieces when I looked at a spring and realised they were rising rate! Another case of armchair engineering not applying in the real world!
Author:  datajon [ Thu Mar 13, 2008 2:49 pm ]
Will run better test, just oem toyota springs require an offset base, will preform a 0 - 500 kg load test now they cannot escape.
Don't have a 205 rear spring to hand, all gone to scrap man.
valve springs table too, will up load
