DIY Jomitry setup (Stoopid idea #455437897543) http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=3064 |
Author: | two_OH_five [ Tue Jul 07, 2009 3:32 pm ] |
Post subject: | DIY Jomitry setup (Stoopid idea #455437897543) |
Not that DJ didn't do a great job with his Carlos Fandango laser setup straight from the bridge of USS Enterprise but I've got a few jobs coming (and one already waiting) up that will require me to do suspension geometry setup These include:- Re-align the rear subframe on the black pig Renew front superstrut on the black pig Polybush rear end of Hannibal Custom geometry setup on Hannibal Adjustable topmounts on Hannibal Adjustable rear arms on Hannibal etc etc With all of these in mind I'm going to need to sell one car to pay for alignments on the other if I have to pay for them ![]() So I'm going to revert back to old school basics with a tape measure and calculator. I think I've designed a jig (during lunch if the boss is looking ![]() A few enhancements might even allow for ackermann (not that I can do squat about it ![]() Has anyone mucked about with this sort of stuff in the past? Any comments will be welcome (apart from the obvious skinflint/you tool ones, we all know that anyway!) Course, if someone wants to donate a 4 wheel alignment rig this will all go out of the window ![]() |
Author: | two_OH_five [ Tue Jul 07, 2009 4:11 pm ] |
First pass at a wheel alignment frame. 4 will be required, one per wheel ![]() (image in full res here) |
Author: | two_OH_five [ Tue Jul 07, 2009 4:38 pm ] |
How to use it for toe and thrust angle ![]() (image in full res here) |
Author: | two_OH_five [ Tue Jul 07, 2009 4:45 pm ] |
It should be possible to measure KPI by taking camber measurements at +10deg and -10deg of steering input. This will require the construction of a wheel angle plate. I have an idea for that ![]() |
Author: | two_OH_five [ Tue Jul 07, 2009 5:04 pm ] |
I should add that the adjustable height means that it should be possible to use this on a non level surface (within reason). This means it should work on my drive Using a 4 wheel "U" tube water spirit level, one per alignment frame, means I can set all of the hubs at the same height. |
Author: | Nibbles [ Tue Jul 07, 2009 5:50 pm ] |
I'm an even bigger skinflint ![]() For toe, I just stop on a flat piece of ground and sight along the wheel to check front and back line up with the wheel at the opposite end (taking into account any difference in width front to back). Alternatively, a long straight pole. I normally get it more accurate (less uneven tyre wear) that most tyre places. I also favour the use of sliding plates you drive over to check wheel alignment as these take into account flex in all the suspension joint with normal loading. For camber, park the car on a FLAT LEVEL piece of ground and use a vertical spirit level and ruler to measure distance from vertical over the height of the wheel. For checking position of wheel relative to body (subframe alignment etc.) I would just use a tape measure to a reference point such as centre of bottom swivel. Not the most accurate, but it depends if you're looking for the last 1/100th second on a laptime or something that's ok on the road without wearing tyres in no time. |
Author: | DeeCee [ Wed Jul 08, 2009 12:17 am ] |
On a video I watched of some Aussies over at Tsukuba for time attack, they used some stands with metal wires on them and then measured off the wheel against the tyre. |
Author: | Meurz [ Wed Jul 08, 2009 8:35 pm ] |
Like this ![]() ![]() |
Author: | two_OH_five [ Sun Jul 12, 2009 9:47 pm ] |
![]() Stringed it up the old fashioned way. If you squint you can just about make out the fishing line I used ![]() (Just for Kris, it was stren 40lb test shock leader ![]() ![]() Offside rear was toed in by 1.5deg, ns rear toed in 0.5 deg Both sides now toe in 0.3deg ![]() Car now goes in a straight line with the steering wheel centred ![]() |
Author: | TrackToyFour [ Sun Jul 12, 2009 10:46 pm ] |
Did you lock the steering wheel/front wheels in the straight ahead position to get the string lines aligned or did you just eyeball it? |
Author: | two_OH_five [ Sun Jul 12, 2009 11:12 pm ] |
Measured it It doesn't actually make that much difference - there's a screw centred on the hub for setting up the strings. As you turn the front wheels the head of the screw doesn't actualy move in very much for the first few degrees of turn It's all down to sine waves ![]() The wheel "attachments" - the screw is dead centre and used for setting up the string lines ![]() Ghetto "Slippy Slidey plates" TM, pat pending Made out of 2 bits of kitchen worktop and well greased. It allows the wheels to adopt a normal position when lowered off the jacks and provides much needed clearence under the car for twiddling the adjusters ![]() |
Author: | Nibbles [ Sun Jul 12, 2009 11:29 pm ] |
Quote: Ghetto "Slippy Slidey plates" TM, pat pending
Made out of 2 bits of kitchen worktop and well greased. Now that's more like it ![]() |
