http://www.gt4dc.co.uk/forum/
Gt4 Head Bolts Splined Socket Size?
http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=3274
Author:  Exup [ Sat Nov 07, 2009 12:20 am ]
Post subject:  Gt4 Head Bolts Splined Socket Size?
Anyone know the splined socket size for the cylinder head bolts on a 205 gt4?
I only want one socket, i don't want to purchase a whole set of these as i don't have any use for any for the others.
Author:  Diceman [ Sat Nov 07, 2009 12:41 am ]
It is very worthwhile getting some advice on the type of socket also.
IIRC you need a long shaft on the spline to clear the head casting. At least I think you do on the ST185 and the Halfords type clash with the casting :-(
Author:  Exup [ Sat Nov 07, 2009 2:35 am ]
My cylinder head is a st185, with a St205 bottom end i should of said.
Author:  Nibbles [ Sat Nov 07, 2009 11:43 am ]
They're 10mm.
Heads are 12 point but if you're careful you can normally get away with a normal 10mm allen key type bit.
Ideally you need a long version otherwise you need to remove cams. I have been known to cut the angle off a normal allen key and use a 10mm socket on it ;) If the cams are coming out anyway, you can use a normal short bit.
If you use ARP studs, you'll need the cams out anyway. On a 185 head, there's also a bit of casting which fowls the back of the socket needed, so you need to check and grind away the offending piece before final cleaning & assembly so you can get rid of the dust.
