Optimum placement of undertray slotted air outlets using CFD http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=4118 |
Page 2 of 2 |
Author: | Dan [ Mon Oct 04, 2010 9:10 pm ] |
Sunny wrote: i think you should start the programm once again with engine bay flow to get a correct sight of things.......air is a hart to appraising medium
I will give it a go. |
Author: | Sunny [ Tue Oct 05, 2010 5:34 pm ] |
Hi, no one is joking, ok looks like is should be quiet greetz |
Author: | Wolf_Tm [ Tue Oct 05, 2010 5:46 pm ] |
Sunny wrote: Hi,
no one is joking, ok looks like is should be quiet greetz Sunny, I was just trying to explain you that no one was joking about this argument... I suspected you didn't understand when we were talking about "wool", but this was not a joke, but a serious thing: BAUMWOLLE What I said it's that the "old" wool method worked for me to understand where I'm getting pressure/vacuum in the car... Wolf |
Author: | Sunny [ Tue Oct 05, 2010 8:23 pm ] |
Hi, now i understand greetz |
Author: | Wolf_Tm [ Tue Oct 05, 2010 9:30 pm ] |
Sunny wrote: Hi,
now i understand greetz Perfect! That's why I told you that hood shims and no seal worked for me... Wolf |
Author: | two_OH_five [ Tue Oct 05, 2010 9:47 pm ] |
woohoo, my oil cooler idea should work. I want to lay it flat on the undertray with some ducts like your wireframe for the exhaust outlet from it Interesting fact, in NHRA racing the vertical exhaust stacks geneate something like 200N of downforce on full chat |
Author: | Dan [ Tue Oct 05, 2010 10:21 pm ] |
two_OH_five wrote: my oil cooler idea should work. I want to lay it flat on the undertray with some ducts like your wireframe for the exhaust outlet from it
So the cooler is mounted in the horizontal plane??? Will the 'through draft' be sufficient, or will you need to use some sort of conformal ducting to blow air over the coolers - NACA ducts etc? |
Author: | coyoteboy [ Tue Dec 14, 2010 11:46 am ] |
On a side-note, and I LOVE that you're going at this down the proper route of CFD (and you've inspired me to crack out NX and have a play!) what are the implications of undertrays with the MOT. As far as I'm aware, the MOT are not allowed to remove anything to test/visually inspect. If you cover the bay area/any suspension/brake/fuel pipework, can they refuse to test or do they just bypass that check? |
Author: | Corey Darling [ Thu Jan 12, 2012 8:25 pm ] |
Hey, That software looks incredible. I've always wondered how functional the 185 spoiler is. How time consuming is it to throw the tail end of a 185 into that program and see how it performs? Cheers |
Page 2 of 2 | All times are UTC + 1 hour |
