It is currently Sat Apr 27, 2024 11:24 pm
 Post subject: hks pistons
PostPosted: Sat Feb 19, 2011 10:54 pm
hks pistons,
anyone rate them,
compared with je, wiesco, cp, etc,
are they good?
PostPosted: Sat Feb 19, 2011 11:29 pm
Car Model: ST165
i am sure they are fine when brand new
but i think they are only available in 87.00 mm oversize
http://www.nengun.com/hks/forged-piston-kit
103-RT029
Toyota - 3S-GTE - 2045cc - 87 - 22mm
ST165 turbo 4WD
PostPosted: Sun Feb 20, 2011 12:26 am
and goin 87mm isnt advised is it?
even if im only goin for 300-330bhp wud 87mm be alrite?
do blocks crack easier with 87 rather than 86 or 86.5?
PostPosted: Sun Feb 20, 2011 1:02 am
boring out the block to accept 87mm pistons will leave less cylinder wall material so less of a safety margin. If you machine the block and fit cylinder liners then they would be OK
I wouldn't recommend it unless you liner the block
all other things being equal then yes unless you liner the block
Users browsing this forum: No registered users and 103 guests
