It is currently Sun Apr 28, 2024 6:12 pm
PostPosted: Thu Mar 10, 2011 2:20 pm
got a power fc on my 205 all set up last august by 2bar tunning. all ok up until last night when driving normal (4th gear 40mph) the e-man light came on for about 3-5secs then went out and came on again for about the same time. i pulled over to check my commander and didnt find anything wrong knock and intake temps normal.
i assume the pfc wont do flash code diagnostics?
anybody had problems like this?
thanks
PostPosted: Thu Mar 10, 2011 4:34 pm
Flashing light on PFC mostly means det
Do have knock shown on the hand commander an if so what was the peak?
PostPosted: Fri Mar 11, 2011 12:18 am
nah knock was fine 33 at its peak.
it doesn't alter performance at all but today when the light came on it stays solid for 3 secs then goes out then back on for 3 secs ect wether at idle, on boost, all the time.
turned car off then back on and had no light
any ideas?
PostPosted: Fri Mar 11, 2011 2:11 am
I think I've got some stuff about pfc error codes at home somewhere. I'll have a hunt about
PostPosted: Sat Mar 12, 2011 10:15 pm
Means a sensor is out of range...
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Mon Mar 14, 2011 11:37 am
did a sensor check and whilst the light was on the "LVL" one was switching on and off at the same time as the e-man light so what is it for?
PostPosted: Mon Mar 14, 2011 12:45 pm
Usually it's the Throttle Position Sensor that briefly goes out of range, what boost do you run, stock map sensor?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Mon Mar 14, 2011 3:43 pm
1.2bar, yeah stock map sensor
PostPosted: Mon Mar 14, 2011 3:44 pm
got fmic too if makes any difference
PostPosted: Mon Mar 14, 2011 7:01 pm
Hi, Have you got the AP Engineering Power FC or a mr2 unit?
If the latter have you defeated the CC system, not 100% sure if this is necessary when using the PFC but it may explain the LVL warning you are getting?
Are you able to view a voltage/resistance of the 'LVL'?
Not sure what LVL is tbh?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Mon Mar 14, 2011 11:38 pm
yeah its the pfc for the st205 and have found out that lvl is for the charge cooler coolant level. so i checked the piece of wire that i briged the connector with and found it was loose.
i must now remove that connector and solder the wires for a more permenant fix, didn't do it before cos i wasn't sure how i would get on with the fmic.
thanks
Users browsing this forum: No registered users and 90 guests
