It is currently Tue Oct 07, 2025 12:30 am
 Post subject: misfire in rain
PostPosted: Sun Jul 31, 2011 3:26 pm
hey guys ive had a problem with the car for a while even on both motors ive had in the car, when it rains or i clean the car i get low power and alot of missing at around 15psi, this is an st205. I am thinking mabey the dizzy is getting wet?, and my buddy here also has the same problem.
PostPosted: Sun Jul 31, 2011 6:07 pm
The UK is pretty wet and this isn't a common problem here :)
Usual culprits of misfire are ignition related, change/check in this order (imho):
1. Plugs - fit NGK BKR7E for cars upto 400hp
2. Check ignition timing
3. Replace rotor arm
4. Replace dizzy cap
5. Check engine/battery earths
6. Replace ignition leads
If it's a usual problem the above will fix it at your lowest cost :)
PostPosted: Mon Aug 01, 2011 6:27 am
sounds good, thanks again :)
PostPosted: Mon Aug 01, 2011 9:32 am
For misfire when wet I would most suspect external ignition components I.e. leads cracked dizzy cap or rotor arm.
