It is currently Fri Apr 26, 2024 7:49 pm
 Post subject: about piston rings
PostPosted: Fri Oct 21, 2011 12:12 pm
hello, what is the difference between the OEM Toyota piston rings and the after market WISECO/CP/JE piston rings? Is one of them more durable than the other or are all the same? And are the oem rings useable with wiseco pistons?
i talked with wiseco germany, and they say the material from wiseco rings are:
1e ring = Stainless Steel/Gas Nitrided and barrel faced
2e ring = Cast Irion, phosphate coated, taper faced
3e ring = oil pack = Stainless steel flex vent spacer/chrome faced rails
what do you guys think? do the toyota use the same material for the oem rings?
PostPosted: Fri Oct 21, 2011 12:43 pm
OEM rings should not be used with anything but OEM pistons!
The ring/piston interface is critical and the two must be sized to match or there is a good chance of catastrophic damage to pistons and/or bores
If you're going with Wiseco pistons use wiseco rings etc etc
The only exception I'd personally make to that rule is something like totalseal rings where they will consult about the suitability of their rings for other pistons (they do not make pistons afaik)
This opinion was formed after reading a 10 page (yes 10 pages, really!) article on ring design in race engine technology. The only thing I learned from the article was that some things are just too geeky even for me :shock: so best leave it to the design folks with pocket protectors and leather elbow patches
PS
At a guess Toyota may well be cast 1 and 2 ring
PostPosted: Fri Oct 21, 2011 11:05 pm
wow :) thank you very much for the infos...
Users browsing this forum: No registered users and 26 guests
