It is currently Mon Apr 29, 2024 10:21 am
 Post subject: low oil sensor wire/test
PostPosted: Sat Nov 12, 2011 12:36 pm
is there a way of testing the wire-plug that goes into the low oil-level sensor?
ive just replaced the sump with a new (used iteam) ive no reason to think the sensors not working, so woundered if it could be a wireing issue
strange thing is, ive a clifford alarm and when i press the fob to let the
turo timer run, the oil level warning on the dash go`s out
to avoid confussion its a uk car despite my username
PostPosted: Sat Nov 12, 2011 3:27 pm
disconnect the plug and use a small wire for shortening it -> have a look to the gauge cluster
PostPosted: Sun Nov 13, 2011 6:27 pm
thanks for the help
i assume you mean "bridge" the connections in the plug
and see if the light goes out in the dash?
i havnt seen the connections in the plug
are there only 2 in the plug
also strange that activating the turbotimer switches of the light in the dash
PostPosted: Sun Nov 13, 2011 6:49 pm
correct, bridge the two connections
a turbo timer should not effect that.....
PostPosted: Mon Nov 14, 2011 12:48 am
[quote="Sunny"]Hi,
thanks for the confirmation, will try this when ive got time
and go from there
stange about the turbotimer on the keyfob, when switching on the TT
dash light goes out
Users browsing this forum: No registered users and 108 guests
