http://www.gt4dc.co.uk/forum/
Injector deadtimes.
http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=5279
Author:  Nibbles [ Fri Dec 02, 2011 7:50 pm ]
Post subject:  Injector deadtimes.
Just been doing some work with Daryl on my unstable idle, and have discovered the root cause is the injector deadtime table on the link is way way out. As the revs drop, the voltage from the alternator drops which was then richening the mixture too much.
A bit of googling reveals the following useful info:
http://injector-rehab.com/shop/lag.html
Author:  Kris [ Sat Dec 03, 2011 7:42 pm ]
There should be a battery vs injector correction table in the ECU.
As the battery voltage drops then the injectors get lazy and need a bit more of a kick to get them to correctly open up.
This correction table is useful to help get the car started and keep it running when there is additional electrical load applied e.g. rear screen heater, blower etc etc
Author:  two_OH_five [ Sat Dec 03, 2011 8:41 pm ]
sounds like the dead time compensation must be set way too high somewhere
googlemsays pc link has an injector dead time compenstion table if you can find it
Author:  Nibbles [ Sun Dec 04, 2011 12:43 am ]
It was set to 1mS at 14V and 1.1mS at 13V. The injectors are only needing about 1.1-1.2mS at idle (sard 800's running 2 pulses per engine cycle)
