Toyota 503E Engine ITB
http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=5328
Author:  TrackToyFour [ Fri Dec 30, 2011 12:49 am ]
Post subject:  Toyota 503E Engine ITB
Thanks to a recent tip-off I managed to pick up this Toyota independent throttle body and plenum assembly from US fleabay for a bit of a bargain.
It was originally fitted to the 900bhp 2.1 litre turbo Toyota 503E racing engine which was developed from the 3S-GTE and used to power the Toyota Eagle sportscar in the American IMSA series in the early 1990's. It will need some slight modification to fit a 3S-GTE head. Its all cast in magnesium so the whole assembly only weighs 5kg, amazing :) There may not be enough space for this in a GT-Four engine bay but if it can handle 900bhp then who cares :lol: I can always build a car around the engine!
Toyota Eagle MkIII IMSA GTP being demonstrated at the Goodwood Festival of Speed in 2005
Close up of 503E engine and plenum in the Toyota Eagle
Author:  two_OH_five [ Fri Dec 30, 2011 1:13 am ]
Shame you can't photograph the lightness :(
It must be hewn from a finely blended alloy of unobtanium, hens teeth and rocking horse poo
Author:  e834fpb [ Fri Dec 30, 2011 1:44 am ]
would these be a big upgrade compare to single throttle body,
didnt the later corolla wrcs use a similar a set-up
are you in perth or uk too by the way?
Author:  Insanity-74 [ Fri Dec 30, 2011 8:41 am ]
Henobtaniorse ?????
Author:  TrackToyFour [ Fri Dec 30, 2011 11:52 am ]
Yes, the later Corolla WRC with the Lexus derived engine used an ITB for better throttle response. I think Gary posted a diagram of it a few months back.
Author:  Insanity-74 [ Fri Dec 30, 2011 12:13 pm ]
Did it?? i thought it used a double inlet plenium from a single throttle body?? although I'm probably wrong but thats whats in my mind at the moment.
Its strange this has come up as just the day before yesterday I was thinking about the possibilities of making throttle bodies for a ST205.
Edit...just found the link...it did in deed use throttle bodies....hmmmm brain working.
http://www.gt4dc.co.uk/forum/viewtopic. ... 1d6b5f3f84
Author:  Sunny [ Fri Dec 30, 2011 5:52 pm ]
absoute great part :)
but it looks more then just a little work to get it mounted
