st185 rally replica parts? http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=5451 |
Author: | Mr Burt [ Tue Mar 06, 2012 9:28 pm ] |
Post subject: | st185 rally replica parts? |
where can i find the roof scoop,wing mirrors and lamp pods for sale? |
Author: | TrackToyFour [ Tue Mar 06, 2012 10:54 pm ] |
You will probably have more luck on the OC. Guys like Warner (wing mirrors, roof scoop?) and Tim (lamp pod) have made replica ST185 parts recently |
Author: | Gary ST165 [ Wed Mar 07, 2012 9:55 am ] |
GT4OC owns the moldings for all of the above items on your shopping list , hence these items can only be purchased via the GT4OC shop: http://www.gt4oc.net/forums/viewtopic.php?f=74&t=127105 The lamp pods and airboxes etc are GRP replicas taken from genuine TTE parts including TTE airboxes: |
Author: | Sunny [ Sun Mar 11, 2012 8:33 pm ] |
Hi Gary, are there also ST205 parts available? best regards Alex |
Author: | Insanity-74 [ Mon Mar 12, 2012 2:32 pm ] |
The airbox fits the standard ST205 with a bit of modification and I loaned my ST205 Lamp pod to them to take a mould from. |
Author: | Gary ST165 [ Mon Mar 12, 2012 9:54 pm ] |
Sunny wrote: Hi Gary,
are there also ST205 parts available? best regards Alex Sorry Alex, Currently we only have the ST205 TTE airbox ...and maybe Nial's Lamp pod which i wasn't aware of... |
Author: | Sunny [ Mon Mar 12, 2012 11:12 pm ] |
Hi, unfortunelty this isn't really a option for me, headlight and fuse box give it a kick its time to do a air box for people like me with relocated battery and fuse box still in place -> corolla style with cone filter but another two questions, what filter do the TTE box take and did you built them? greetz |
Author: | Gary ST165 [ Tue Mar 13, 2012 2:49 am ] |
Wolfiehere wrote: Mercedes A160, 2 Litre diesel, 2006 model - air filter element is suitable for this Airbox 397x167x60 no, I did not make it. and i don't know the manufactures name off the top of my head, best contact Wolfiehere on GT4OC : aka warner http://www.facebook.com/profile.php?id=1421376994 Wolfiehere wrote: The ST205 Air box will fit the ST185.
I have fitted one in 2 ways now which you will also have to fit in one of the two ways to the ST205, The resonator and drain goes through the inner flitch (wing) panel to the wheel arch. then you attach a pipe from the front to the bottom for a cold air feed and water outlet. You can cut this off and fit the box without cutting the car or you can just cut it out above is pictures as fitted to ST185 in both ways. |
Author: | Sunny [ Thu Mar 15, 2012 8:55 pm ] |
Hi Gary, i'am dont use facebook unfortunelty, and yes this is true are you able to get measurements of the box? also from the box to turbo connector? greetz |
Author: | Insanity-74 [ Tue May 08, 2012 12:47 pm ] |
Sunny wrote: Hi,
unfortunelty this isn't really a option for me, headlight and fuse box give it a kick greetz Me too, the problem is easily solved....cut off the bits of the airbox that you dont need/cant use....then add ducting from a location that you can use!!! |
