It is currently Mon May 13, 2024 6:27 am
PostPosted: Tue Mar 06, 2012 9:28 pm
where can i find the roof scoop,wing mirrors and lamp pods for sale?
PostPosted: Tue Mar 06, 2012 10:54 pm
You will probably have more luck on the OC. Guys like Warner (wing mirrors, roof scoop?) and Tim (lamp pod) have made replica ST185 parts recently
PostPosted: Wed Mar 07, 2012 9:55 am
Car Model: ST165
GT4OC owns the moldings for all of the above items on your shopping list , hence these items can only be purchased via the GT4OC shop: http://www.gt4oc.net/forums/viewtopic.php?f=74&t=127105
The lamp pods and airboxes etc are GRP replicas taken from genuine TTE parts
including TTE airboxes:
ST165 turbo 4WD
PostPosted: Sun Mar 11, 2012 8:33 pm
Hi Gary,
are there also ST205 parts available?
best regards
Alex
PostPosted: Mon Mar 12, 2012 2:32 pm
The airbox fits the standard ST205 with a bit of modification and I loaned my ST205 Lamp pod to them to take a mould from.
PostPosted: Mon Mar 12, 2012 7:32 pm
thats great, but not really in that case it should :lol:
the intake of the airbox is desiged to fit without inner headlight and get the air from this position
not really good becouse i need the lights :(
possible there are any custom builts available from the OC?
PostPosted: Mon Mar 12, 2012 9:54 pm
Car Model: ST165
Sunny wrote:
Hi Gary,
best regards
Alex
Sorry Alex,
Currently we only have the ST205 TTE airbox
...and maybe Nial's Lamp pod which i wasn't aware of...
ST165 turbo 4WD
PostPosted: Mon Mar 12, 2012 11:12 pm
unfortunelty this isn't really a option for me, headlight and fuse box give it a kick
its time to do a air box for people like me with relocated battery and fuse box still in place -> corolla style with cone filter :twisted: :lol:
but another two questions, what filter do the TTE box take and did you built them? :)
PostPosted: Tue Mar 13, 2012 2:49 am
Car Model: ST165
Wolfiehere wrote:
Mercedes A160, 2 Litre diesel, 2006 model - air filter element is suitable for this Airbox
397x167x60
Image Image Image
no, I did not make it.
and i don't know the manufactures name off the top of my head, best contact Wolfiehere on GT4OC : aka warner http://www.facebook.com/profile.php?id=1421376994
Wolfiehere wrote:
The ST205 Air box will fit the ST185.
I have fitted one in 2 ways now which you will also have to fit in one of the two ways to the ST205,
The resonator and drain goes through the inner flitch (wing) panel to the wheel arch. then you attach a pipe from the front to the bottom for a cold air feed and water outlet.
You can cut this off and fit the box without cutting the car
Image Image
or you can just cut it out
Image Image
above is pictures as fitted to ST185 in both ways.
ST165 turbo 4WD
PostPosted: Thu Mar 15, 2012 8:55 pm
Hi Gary,
i'am dont use facebook unfortunelty, and yes this is true :lol:
are you able to get measurements of the box? also from the box to turbo connector?
PostPosted: Tue May 08, 2012 12:47 pm
Me too, the problem is easily solved....cut off the bits of the airbox that you dont need/cant use....then add ducting from a location that you can use!!!
