st185 vsv???? http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=5757 |
Author: | ktmevo [ Mon Jul 02, 2012 6:37 pm ] |
Post subject: | st185 vsv???? |
what is the vsv and where will i find it?? what advantage is there by disconnecting it??? |
Author: | Sirius [ Mon Jul 02, 2012 7:18 pm ] |
The TVSV works to raise boost pressure in the higher gears. There is no benefit to disconnecting it unless you also fit a boost controller. The easiest way of disabling it is to block the pipe that runs backwards from the actuator towards the engine. |
Author: | Meurz [ Mon Jul 02, 2012 11:17 pm ] |
http://turbocelica.nl/howto-tvsv.htm |
Author: | ktmevo [ Wed Jul 04, 2012 9:52 am ] |
well im guessing mine must be blocked...as iv a forge acctuator that only has 1 nipple on the top...pipe to turbo..pulls set boost in all gears. |
Author: | Nibbles [ Wed Jul 04, 2012 12:45 pm ] |
Actually, the easiest way to disable TVSV is cut the wire to the solenoud at the back of the ecu. The pipe that people normally cut is a nightmare to get to, and even worse to recconect when putting the car back to standard. |
