Dipstick Tube Info Needed Please http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=5835 |
Author: | Dorris [ Tue Jul 31, 2012 1:55 pm ] |
Post subject: | Dipstick Tube Info Needed Please |
Hi all has anyone got, or can anyone measure for me, the length of the dipstick tube on their ST185. I’m after the measurement of just the tube its self as illustrated below. Much obliged in advance, Dorris |
Author: | Nibbles [ Tue Jul 31, 2012 2:55 pm ] |
147mm (approx.) Note - the dipstick goes into a raised bit of the block. The measurement is from the raised bit of block at the middle / bottom of the hole the tube goes into. If you measure at the left you get a couple of mm less, the right is on the edge of the step and you'll get a fair bit longer if measuring down to the lower level. |
Author: | Dorris [ Tue Jul 31, 2012 6:20 pm ] |
Nibbles wrote: 147mm (approx.)
Note - the dipstick goes into a raised bit of the block. The measurement is from the raised bit of block at the middle / bottom of the hole the tube goes into. If you measure at the left you get a couple of mm less, the right is on the edge of the step and you'll get a fair bit longer if measuring down to the lower level. Does the base of your dipstick look like this by any chance? Dorris |
Author: | Nibbles [ Tue Jul 31, 2012 7:02 pm ] |
Probably, in which case measurement is from top of raised bit. |
Author: | Dorris [ Tue Jul 31, 2012 10:03 pm ] |
Cheers mate! D |
