M25 to 3/4" Thread Adaptor for oil cooler arrangement http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=6193 |
Author: | jgtcracer [ Mon Jan 07, 2013 7:13 pm ] |
Post subject: | M25 to 3/4" Thread Adaptor for oil cooler arrangement |
I recently purchased a cheap oil cooler setup for the st205. The kit also incorporates a filter relocation kit. The kit is universal and comes with an adaptor that I need to allow the oil takeoff to bolt onto the block. The section that screws onto the block has an m25 thread in it (the adaptor screws into this). As a result I need an adaptor with a M25 male thread to screw into the oil takeoff. Inside this adaptor a female thread needs to be tapped that will screw directly onto the block. This is a similar oil cooler setup http://www.ebay.co.uk/itm/SUBARU-IMPREZ ... RTM1089356 you can just about see the two adaptors in the picture, the one I need has the hex head on it Im really struggling so if anyone has any good hydraulic suppliers it would be appreciated marcus |
Author: | Sirius [ Mon Jan 07, 2013 8:00 pm ] |
Post subject: | Re: M25 to 3/4" Thread Adaptor for oil cooler arrangement |
I can't find anything like that from the place I usually use - ThinkAuto. It might be easier to just buy a mocal takeoff plate with -10 fittings on it. Also that kit doesn't appear to have a thermostat in it? |
Author: | jgtcracer [ Mon Jan 07, 2013 8:16 pm ] |
yea, Im using a thermostat up at the filter relocation bit, need to get this part fitted 1st though cheers |
