battery earth http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=6194 |
Author: | sketchmyster [ Mon Jan 07, 2013 9:24 pm ] |
Post subject: | battery earth |
[*]Just want to know I've been having a problem with the celica st185 when I go to start it it struggles when I looked I noticed the earth wire getting really hot could this be a problem |
Author: | jgtcracer [ Mon Jan 07, 2013 9:42 pm ] |
Post subject: | Re: battery earth |
heat would suggest an excessive current flowing through it. Is that cable in good condition, what are the connections like?? |
Author: | sketchmyster [ Mon Jan 07, 2013 10:19 pm ] |
Connection 1 end is ruined so replacing that tomorrow |
Author: | Nibbles [ Mon Jan 07, 2013 10:35 pm ] |
Which wire is getting hot ? The one from battery direct to engine ? Is the whole wire getting hot, or just the connection end ? Poor connections drop voltage and therefore get hot. |
Author: | sketchmyster [ Mon Jan 07, 2013 10:38 pm ] |
It's a earth in the engine not to the battery |
Author: | two_OH_five [ Mon Jan 07, 2013 10:45 pm ] |
Which one though. The small one by the alternator or the main braid? If it's the small one then chances are you have lost the main connection which runs from the battery to the gearbox |
Author: | sketchmyster [ Mon Jan 07, 2013 11:03 pm ] |
It comes off the starter was the original one to the battery but had the battery converted to the boot |
Author: | NoGT4 [ Mon Jan 07, 2013 11:08 pm ] |
I picture with annotations would help. Was the battery relocation done with the correct gauge cables? |
Author: | sketchmyster [ Mon Jan 07, 2013 11:17 pm ] |
Yer it was. It wasn't a good connection so was going to change it for a slightly better gauge as for photo will get 1 tomorrow |
Author: | Nibbles [ Tue Jan 08, 2013 2:21 am ] |
If the battery earths to body in the boot then the heavy wire from starter that used to go to battery needs to go direct to a good body earth. The old thinner cable from battery to body isn't man enough for starter current. |
Author: | sketchmyster [ Tue Jan 08, 2013 1:16 pm ] |
All sorted new higher grade wire fitted running sweet |
Author: | NoGT4 [ Tue Jan 08, 2013 2:15 pm ] |
Happy days sketch |
Author: | sketchmyster [ Tue Jan 08, 2013 5:58 pm ] |
Now for new power steering pump |
