It is currently Mon Apr 29, 2024 3:09 pm
 Post subject: Ignition switch current.
PostPosted: Wed Aug 28, 2013 1:08 pm
Anybody know what the max current switched by the ignition switch is? engine on and the cranking position please?
St205 WRC - Running sweet.
PostPosted: Wed Aug 28, 2013 8:09 pm
It won't be much more than non cranking. Its mostly switching relays on. Or heavy duty starter solenoid.. Which is from a relay IIRC
Darryl
Darryl
PostPosted: Wed Aug 28, 2013 8:30 pm
Yeah, it is only controlling relays, etc, so why do you ask?
GT4 Pub quiz ? :D
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Wed Aug 28, 2013 10:19 pm
Desperately hopes the word pushbutton doesn't feature in the answer......
Ill guess sub 5A
PostPosted: Wed Aug 28, 2013 10:45 pm
Remote start (radio) while make my coffee..
PostPosted: Wed Aug 28, 2013 10:48 pm
I believe the various poles of the first 2 positions do carry a fair bit of current, they certainly have some pretty substantial cable to them (5mm sq ish). Pretty sure the starter bit just carries a relay drive. I know the immobiliser fitted to my car was switching these lines behind the dash and both relays burnt out after a time.
PostPosted: Wed Aug 28, 2013 10:51 pm
The Toyota receiver died so made a new one + keyfob. As the fob has 5 buttons, I thought id make use of them.
PostPosted: Wed Aug 28, 2013 10:54 pm
Fat relays it is then.... My old work has plenty to choose from....
Users browsing this forum: No registered users and 113 guests
