It is currently Fri Mar 29, 2024 1:22 am
 Post subject: Gear box noise
PostPosted: Tue May 19, 2015 10:40 pm
Every time i put my car in gear go to drive of a noise starts like there's a buzzing sound like sound of a fan R something any suggestions please
 Post subject: Re: Gear box noise
PostPosted: Tue May 19, 2015 11:38 pm
Need more detail to diagnose. Does the noise only start when you engage gear but still have the clutch pedal depressed or does the noise only start when you let the clutch out and the car is under way?
PostPosted: Tue May 19, 2015 11:50 pm
It starts when the clutch is out an car moves of
PostPosted: Tue May 19, 2015 11:59 pm
Might be the clutch release bearing on the way out. Is the clutch friction plate original? Might be another culprit depending how much abuse its had over the years.
PostPosted: Wed May 20, 2015 12:18 am
For got to say it still makes that noise when it's takeing over just siting there no clutch prest are anything and after few minutes it stops
PostPosted: Wed May 20, 2015 8:20 pm
The noise is from the air water intercooler pump it's probably done
PostPosted: Wed May 20, 2015 9:02 pm
If the pump is gone then you should see little or no fluid movement in the charge cooler when you remove the cap.
You can get exchange reconditioned pumps from Steve at GT4-Play at:
http://www.gt4-play.co.uk/catalog/produ ... ucts_id/32
PostPosted: Wed May 20, 2015 10:22 pm
I'll check that tomorrow would it b dangerous to keep driving it
PostPosted: Wed May 20, 2015 11:04 pm
If you keep off boost and drive like a granny then you should be OK.
PostPosted: Wed May 20, 2015 11:56 pm
Lol cheers I tink I'll just get one of that of that web site
