It is currently Fri Apr 26, 2024 7:39 pm
PostPosted: Sat Dec 05, 2015 9:14 pm
Just put my old turbo housing through the parts washer after stripping it down, and found cracks internally.
See pics
Is this common, or a cause of potential failure?
Sent from my SM-G928F using Tapatalk
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Sat Dec 05, 2015 10:41 pm
I've heard reports of the TTE inconel turbine housing failing in spectacular (and expensive) fashion. I guess if your turbo has seen high boost and/or experienced some sort of thermal shock then it could result in cracking?
As a matter of interest, what was your intention with this turbo by stripping it? They're not exactly the sort of component you can rebuild yourself!
PostPosted: Sun Dec 06, 2015 12:07 pm
Just planning to get it rebuilt so thought I'd strip it down and clean the casting.
There is about 8 cracks in total, and if a piece comes off all bets are off.
Sent from my Sony Xperia Tablet
Hybrid turbo
Apexi AVC-R
PostPosted: Sun Dec 06, 2015 4:10 pm
Sounds like it's only fit for the skip Phil. I think JP has a secret stash of turbos if you need a rebuild candidate :twisted:
