It is currently Tue Jun 04, 2024 2:40 pm
 Post subject: ST165 clonking
PostPosted: Thu Nov 12, 2009 2:51 pm
Hi guys, posting here as i dont have access to post in tech :S
Getting a clonk when changing from 1-2-3rd, would suggest its the rear diff mount but i have had a look at it and its not too bad, hasnt collapsed or anything
Is the anything else it could be?
PostPosted: Fri Nov 13, 2009 12:29 am
A torn diff mount and sometimes the driveshaft bearings can be an issue.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Fri Nov 13, 2009 2:05 am
does sound like classic diff mount but it could also be the exhaust rattling about
PostPosted: Fri Nov 13, 2009 2:57 pm
Cheers guys
think its most likely the diff mount bush, whats the best thing to do? pay the £100 for a new bush
Or the £20 to cast a urethane one?
PostPosted: Fri Nov 13, 2009 4:16 pm
up to you.
I cast my own but more to find oit what's involved than for a good technical reason :lol:
PostPosted: Sun Nov 15, 2009 12:08 pm
Doesn't http://www.tcbparts.co.uk offer these for ~£65?
PostPosted: Sun Nov 15, 2009 2:21 pm
Currently on special offer at £98 at TCB
http://www.tcbparts.co.uk/new_products.htm
I don't know where you are located but if near London I got mine fitted by www.cheaptoyotaparts.co.uk for around £125.
PostPosted: Sun Nov 15, 2009 3:08 pm
if you are interested, should fit the ST165
http://gt4dc.co.uk/forum/viewtopic.php?t=3268 :)
PostPosted: Wed Nov 18, 2009 9:13 am
If it's not the rear diff mount, check your sway bar mounts. I had clunking from worn sway bar bushings.
88 ST165...AllTrac!
http://www.toyotacelicaonline.com/112rick.htm
89GTS...ol' faithful
http://www.toyotacelicaonline.com/067rick89gts.htm
Great White North, Canada
