It is currently Thu Mar 28, 2024 11:30 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: PART NUMBERS STICKY
PostPosted: Wed Oct 01, 2008 12:30 pm
PLEASE DON'T POST IN THIS THREAD
I will try and maintain the list of parts from the Parts list thread for ease of use.
If you can't find what you are looking for try here:- http://www.toyodiy.com/parts/
Then post here :- http://gt4dc.co.uk/forum/viewtopic.php? ... highlight=
With the information.
Model, Category, Description, Part Number, Cost,
UNIVERSAL
St205 & st185 REAR DIFF MOUNT CUSHION 52291-20010
ALL Toyota 'For-Life' Coolant 04C0702 COOLANT 08889-80002 £13.00
ST185/ST205 Oil Filter OIL FILTER 90915-10004 £7.78
ALL Sump Plug Gasket GSKT, DRAIN PLUG 90430-12028 £1.22
ST185
St 185 rear drop link 48830-20010
St 185 rear drop link nut 90179-10054
St 185 Front n/s hub Assembly 43502-20100
St 185 cs/rc Front bumper lower grille 53102-20030
St 185 Ht Lead set (5mm) 90919-21524
St 185 Distributor Cap 19101-88364
St 185 Rotor Arm 19102- 74040
St 185 Knock Sensor 89615-50010
ST185 Thermostat THERMOSTAT 90916-03075 13.87 *2 versions??
ST185 Thermostat Gasket GSKT, WATER OUTL 16325-62010 4.06 *2 versions??
St205, Brakes, Front Brake Caliper Pins, 90240-06019,
ST205, Brakes, Front Anti-Rattle Spring, 47748-14080,
ST205, Brakes, Front Pin Retaining Clip, 90468-12022,
St205, Brakes, Rear Brake Caliper Pins, 90240-06017,
ST205, Brakes, Rear Anti-Rattle Spring, 47748-14090,
ST205, Brakes, Rear Pin Retaining Clip, 90468-12020,
ST205 gearbox exhaust hanger bracket, 17571-74221
ST205 front caliper overhaul kit, 04479-20260
ST205 knock sensor, 89615-20060
St205 Cap 19101-88460,
ST205 rotor 19102-74040
ST205 IC Badge PLATE, ENGINE SP 11286-88480 £4.50
ST205 Bonnet Vent Grille PLATE, BULGE 76190-20010 £23.71
ST205 Parcel Shelf Clip CLAMP, PACKAGE TRAY 64324-20051-22 £5.05
ST205 Parcel Shelf Clip BRACKET, PACKAGE TRAY 64323-20061-22 £4.61
ST205 100A Main Fuse FUSE 90982-08246 £9.35
ST205 Thermostat THERMOSTAT 90916-03100 £13.85
ST205 Thermostat Gasket GASKET, HOUSING 16325-63011 £1.06
ST205 Front Top Mount Nut NUT 90179-10095 £1.06
ST205 Chargecooler to Throttle body connector CONNECTOR, INTAK 17861-88480 £22.92
ST205 Hydraulic Tensioner TENSIONER ASSY 13540-88480 £39.22
ST205 Pulley IDLER, S/A, TIMIN 13505-88480 £71.26
ST205 Oil Pressure Regulator REGULATOR 15310-88460 £18.44 ??
ST205 Gasket for Oil Pressure Regulator GSKT, OIL REG 15318-88460 £3.03 ??
ST205 Gearbox Drain/Fill Gasket GASKET 90430-18008 £1.23
ST205 Rear Differential Drain/Fill GSKT. DRAIN PLUG 12157-10010 £1.80
ST205 Rear Anti-Roll Bar Droplink LINK ASSY, RR STABILI 48830-20010 £33.07
ST205 Front/Rear Anti-Roll Bar Droplink Nuts NUT 90179-10183 £0.59
ST205 Figure 8 - Camber Link ARM SUB-ASSY, CAMBER 48066-20061 £60.00 TCB
ST205 Tie Rod - Number 1 Arm - RHS ARM ??? 48068-29195 £130.00 TCB
ST205 Tie Rod - Number 1 Arm - LHS
ST205 Track Control Arm - Number 2 Arm RHS ARM SUB-ASSY 48605-29025 £210.00 TCB
ST205 Track Control Arm - Number 2 Arm LHS ARM SUB-ASSY 48606-29025 £210.00 TCB
ST205 Rear Suspension Strut to Hub Bolt BOLT 90105-15001 2.06 90105-15001
ST205 Rear Suspension Strut to Hub Nut NUT 90179-15001 2.88 90179-15001
ST205 Split Pin COTTER PIN 95381-03025 0.28 95381-03025
ST205 Nut Cap CAP FR WHEEL 43525-20050 1.10 43525-20050
ST205 Nut Front Strut to Fig 8 NUT 90179-16027 1.04 90179-16027
ST205 Nut Front Hub to Lower Arms NUT 90171-14007 0.85 90171-14007
ST205 Nut Fig 8 to Lower Arm NUT 90179-16027 1.04 90179-16027
ST205 Tie Rod Collar/Bush COLLAR/BUSH 90389-21003 2.60 90389-21003
ST205 Track Control Arm Bolt BOLT 90119-14084 2.96 90119-14084
ST205 Tie Rod Bolt BOLT 90119-14052 2.68 90119-14052
ST205 Rear Topmount Nuts NUT 90179-08122 2.41 90179-08122
ST205 Rear Brake Pin Clip CLIP 90468-12020 0.46 90468-12020
ST205 Rear Brake Rattle Spring SPRING, RATTLE 47748-14090 4.39 47748-14090
ST205 Rear Brake Pad Pin PIN 90240-06017 0.93 90240-06017
ST205 Coat Hook HOOK, COAT 74631-20060-22 4.36 74631-20060-22
ST205 Rotor Arm ROTOR, ASSY 19102-74040
ST205 Spark Plug SPARK PLUG 90919-01180
ST205 Distributor Cap CAP ASSY, DISTRIBUTO 19101-88460
ST205 Rear Brake Disc DISC RR 42431-20280 69.00 CTP
ST205 Fuel Pump Bracket, 23206-74760
ST205 Gasket for fuel pump bracket, 77169-14010
ST205 Rear Brake anti-rattle clips (top of caliper) 04948-14010
ST205 Rear handbrake shoe, NS, trailing 46590-33020
ST205 Handbrake mechanism lever, NS, 47612-20030
ST205 rear caliper overhaul kit, 04479-20270
ST205 Piston, rear - 47731-20230
ST205 Differential ring gear backlash adjustment washer, 2.52mm, 90201-54011
