It is currently Mon Apr 29, 2024 9:26 am
 Post subject: Unusual crunching sound
PostPosted: Sun Dec 04, 2005 12:12 pm
Got in the car this AM and with the car stationary I turned the steering wheel each way and got a crunching type sound.......not noticed this before...... :shock: anyhoo...as I reversed to pull away and put the steering on full lock it didn't make any crunching noise and just the usual sound of the PS pump working....same when I turned it full lock the other way.....
I have not yet done obvious checks like check the tightness of the wheels bolts so I'll do that today in my lunchbreak....any ideas what it may be? :? arb bushes perhaps? tie rods?
Cheers
Steve
PostPosted: Sun Dec 04, 2005 2:11 pm
I have now checked the wheel bolts and they are nice and tight. The car passed and MOT at the end of October...surely any damaged / badly worn bushes would have been spotted? :?
PostPosted: Sun Dec 04, 2005 2:16 pm
erghh are you sure there wasnt just a a load of small stones under teh wheels? It is difficult to assist in diagnosing a problem by a description of a sound sorry m8 - wish I coudl be of more help
PostPosted: Sun Dec 04, 2005 2:33 pm
Definatley not small stones.......had a mechanical sound to it......unless the pads were sticking to the discs or something.... :? PS fluid level lookes good.I'll have to check the quality which I have not yet done.
:oops:
Another thing on my 'To Do' list tomorrow/tuesday.
PostPosted: Sun Dec 04, 2005 3:26 pm
Dont wana put the wind up you mate but its not unknown for the steering rack on 185's to come loose by tearing the brackets off the bulkhead :?
PostPosted: Sun Dec 04, 2005 4:48 pm
Lol.....no wind up me...if that was the case then you'd notice it in the cars handling. The car handles fine indeed.
PostPosted: Mon Dec 05, 2005 2:11 pm
hi steve,
just read ur profile thought your car was a 205 then saw ur lights were up.
What is an incident coordinator?
do you make things happen? :lol:
THIS IS MY 4. THERE ARE MANY OTHERS LIKE THIS ONE, BUT THIS IS MINE.
red st185, running 10 psi all gears, powerflow cat back, and air filter. oh and fab scoop splitters
PostPosted: Mon Dec 05, 2005 2:16 pm
I work for a business systems support company. It's my job to send out engineers to companies such as Barclays Bank to fix their problematic hardware/software. We do work for Dell, Whsmith and numerous other companies. It's stressful and demanding......thats why I'm looking for another new job.
Yep I have the st185.....st205 was way over my budget......
Have you any suggestions for my crunching sound? Although having said that it appears to have gone now... :? will it come back again? I'll know later............
PostPosted: Mon Dec 05, 2005 2:17 pm
hi again steve<
does your car make the noise only when you turn your wheell stationary?
does it shake quite bad like its wont let you turn.
Hopefully not, but i had this, the car was fine when driving but at stationary (intermitantly iirc) the wheel had a thrombie.
took it to my man and he eventually said that one of the bolts to the power steering motor/pump had snapped or cracked or something anyhoo he replaced it and it ok.
but if it is this make sure you get your belt changed or at least checked. in case of the obvious things that happen to belts in this situation.obviously
mahender
PostPosted: Mon Dec 05, 2005 3:52 pm
make sure your power steering fluid is topped right up. My 182 done the same thing. I checked the level which seemed ok, as days passed the crunch got louder, then I poured fluid in until I could see it over the max mark. Never heard a peep from it after that point.
Worth checking, common complaint from new 185 owners.
Cheers,
tone
Now offering:
PostPosted: Mon Dec 05, 2005 4:45 pm
It appears to have gone....however I'll be giving the car a good checkover tomorrow.
It may even be worth getting the fluid drain and refilled. I don't know how long it's been in there.
Steve
Users browsing this forum: No registered users and 205 guests
