Rear washer - MOT requirement? http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=424 |
Author: | Sirius [ Fri Dec 23, 2005 1:43 pm ] |
Post subject: | Rear washer - MOT requirement? |
Does anyone know if the rear washer is tested in the MOT? Mine is not working - I don't want the car to fail on something silly. |
Author: | mahender [ Fri Dec 23, 2005 2:54 pm ] |
mine hasnt worked for time. I didnt fail the mot. i assume you mean the water not the actual wiper. |
Author: | CEL1CA [ Fri Dec 23, 2005 4:25 pm ] |
Front washers yes, rear washers....... computer says no.... |
Author: | Candyman [ Fri Dec 23, 2005 10:03 pm ] |
I think it's one of those things where if you have it it is supposed to work, but most MOTers won't notice or care. |
Author: | Terry_T [ Fri Dec 23, 2005 10:19 pm ] |
Did not check mine last week |
Author: | Sirius [ Sat Dec 24, 2005 12:55 am ] |
Thanks guys - its working now - turned out to be a kinked hose at the join between the body and the hatch. Nice easy fix with e bit of plastic cable conduit. |
Author: | mahender [ Tue Oct 30, 2007 1:12 pm ] |
hey all, i know this thread is mega old, but.... my front washer has stopped working and as said earlier my rear died years ago. obviously it is slightlty more imerative the front works. iam gonna check the tubing incase its kinked. but on the off chance it is foobar. where are the motors fr the front and rear washers please. BTW my headlight washers wrok and it says in the book that they three washers run from the same fuse so it cannay be the fuse. or could it???? thanks for your help or any suggestions would be top. thanks.... Happy halloween |
Author: | mahender [ Tue Oct 30, 2007 3:36 pm ] |
hello again, been out to check it. fuse ok. washer not doing anything non motor noise from the window washer and defo the rear washer. headlight washer is fine and window blades are wiping. would you think its a foobar motor or anything else? help greatfully aprreciated as always. thanks.... |
Author: | TrackToyFour [ Tue Oct 30, 2007 6:03 pm ] |
Mine has had the same problem since I got it Rear wiper works OK but no fluid comes out the washer nozzle I believe the rear washer takes its feed from the same pump as the front washers? Can anyone confirm this? I guess I need to track the hose back from the nozzle to see if its kinked in any way. That will be the easy fix :fingers crossed: |
Author: | robbiemcvee [ Tue Oct 30, 2007 7:58 pm ] |
yes it does Don, the hose runs along the drivers side near the door.. |
Author: | Sirius [ Tue Oct 30, 2007 8:49 pm ] |
Mahender - I would say Motor or wiring - if you can get to the pump you can try doing a check with a multimeter on the wires to see if the pump is receiving 12v. If not then I would look at replacing the pump. Don - to confirm what robbie said its the same pump. My line was kinked just where the hose passes from the main body into the rear hatch - I would investigate there first. |
Author: | mahender [ Thu Nov 01, 2007 7:57 pm ] |
thanks sirius. where would the washer motor be please? i have looked in the repair manual but cannot find. thanks. |
Author: | peterp1per [ Thu Nov 01, 2007 8:02 pm ] |
it's located at the front of the offside front wing, if you pull down the arch liner you will see the washer bottle with the pump attached to it. |
Author: | mahender [ Thu Nov 01, 2007 8:24 pm ] |
thanks peter, i though it was gonna be from inside the bay. major jobby. will have a butchers this weekend. |
Author: | peterp1per [ Thu Nov 01, 2007 10:22 pm ] |
mahender wrote: thanks peter, i though it was gonna be from inside the bay. major jobby. will have a butchers this weekend.
it's a fairly easy job mate. Jack the front up and start removing the arch liner from under bumper backwards, you won't need to fully remove the arch liner before you find it. if your planning on removing the pipes or the motor while there's water in the bottle, be prepared to get wet |
